Injectors
Old Nov 14, 2010 | 03:42 PM
willdrew's Avatar
Injectors
How much can the gm stage 2 42lb injectors take power wise???
Old Nov 14, 2010 | 06:09 PM
BlackMagic's Avatar
on gas do not go below a 2.9 or you will be cutting it close. as far as power is concerned I would probably say around 240whp maybe 250whp
Old Nov 14, 2010 | 06:12 PM
Perfect.disguise's Avatar
Octane? E-85? Turbo? SC? Nitrous? etc.
Just have to watch your IDC's on them though just a bolt on SC 2.9 is the "safe" limit..
mexi_loco's Avatar
with injectors, it's not about how much power can they make, but rather it's about the duty cycle. They are more prone to going static if you introduce too much air to the fuel mixture.
Old Nov 16, 2010 | 01:46 AM
skymike83's Avatar
new to cobalts
Hey guys
how Do i know if i have stock injector? the ones i have on the car are lime green color now!
I just got the car a few weeks back so im not sure what the last person before me did to it
Old Nov 16, 2010 | 02:12 AM
cottrezee's Avatar
Originally Posted by skymike83
Hey guys
lime green is stock IIRC
Old Nov 16, 2010 | 11:36 AM
ULWizSS's Avatar
I am on 42 and made 253hp last time i was on the dyno. Injectors with the tune are getting close to the max of what they can handle. Hence the reason for my upgrade coming this weekend.
Old Nov 16, 2010 | 11:43 AM
Staged07SS's Avatar
Administrator
Administrator
I'm currently on 42's with a 73mm pulley, and my car puts down 273 whp on 93 octane and 282 whp on 100 octane mode. Although, I'm not running the M62 it still gives an idea of what the 42's can handle if modded correctly. GM Engineer Bill (more tq more hp) claims the 42's can handle a good amount of power. Remember GMS3 cars use 42lb injectors, and on nitrous mode can make upwards of 300 whp. I would recommend getting 60's though in order to keep injector pw's at bay.
I'm more than likely switching to 60's over the winter to support the 2.7" pulley setup I'm thinking about going with.
Old Nov 16, 2010 | 03:06 PM
skymike83's Avatar
ok i figured they were, could it be possible that another company would make lime greens ones as well.
If they are stock then it would explain why im popping codes and the car is running ruff.
Old Nov 16, 2010 | 05:43 PM
Staged07SS's Avatar
Administrator
Administrator
Nope.
Those are def the stock injectors.
Old Nov 17, 2010 | 12:50 AM
skymike83's Avatar
Nope.
You recommend any good injectors, maybee zzperformance??
Im running or at least got the car running with a 2.900 biletflow pully !
Old Nov 17, 2010 | 01:09 AM
G11's Avatar
G11
^^^suprised he hasn't blown anything.... you need at least 42's with that small of a pulley maybe even 60's if you plan to do more to it
Old Nov 17, 2010 | 07:06 AM
Staged07SS's Avatar
Administrator
Administrator
Take it off until you get 42's or 60's man.
The stock injectors are pretty much maxed on the stock 3.35" pulley. I can only imagine what your pw's look like with a 2.9" pulley right now.
Yes, i would look into ZZP's 60lb/hr injectors. Their injectors (well they arent really their injectors) are a nice price, and include the injector harness for only $25.
Old Nov 18, 2010 | 10:48 PM
skymike83's Avatar
Cool
Believe me the car is driving very ruff, i got the car with the pulley on it already and i do not have another one to put on. I will def look into those zzp's and get them asap because i know the car needs it. thanks for the advice i really appreciate it...
DO you think a good tune will be needed as well? and where should i go for that ?
and what do you mean by pw's ?
Old Nov 19, 2010 | 12:10 AM
Area47's Avatar
Rent me! per hour
getting your information from a glorifed PR guy isn't what i would call accurate.
270 is pushing it.
Old Nov 19, 2010 | 07:19 AM
Staged07SS's Avatar
Administrator
Administrator
You will def want to get a good tune once you switch to different injectors and pulley sizes.
PW = Injectors Pulse Widths
If you have an interceptor or hpt tuners you can determine how hard your injectors are working by monitoring your injector PW's.
Old Nov 19, 2010 | 11:51 PM
skymike83's Avatar
Just ordered some 60lb off zzp's with the harness as well. Hope i get them soon , im going to jut leave the pulley thats on now when i put in those new injectors as well.. I wondering how my mpg will be after the new injectors.... cuz right now my car feels like a v8 lol
thanks again
Old Nov 20, 2010 | 12:20 AM
BlackTVS's Avatar
Your gas mileage isn't going to change from injector to injector as long as the tunes are correct. You obviously need to change your tune whenever you change injectors just to let you know in case it wasn't mentioned.
Either way though going back to the gas mileage side of things, your stoich air to fuel ratio, which should be 14.7 whenever you are not wide open throttle, is always the same. So if you are not requesting a lower stoich, aka 14 flat, then you are not using any more fuel.
Fuel consumption is more about how much your foot is in it, and how well your car is dialed in. If you are running extremely rich because your maf is not dialed in correctly, then you might be using to much fuel. Most cobalts that are modded actually get BETTER fuel economy because of more air entering/exiting there cars at a better rate vs stock. The easier you make things flow and the lighter the car is, the less gas you will use .
So ya, whether you use stock injectors or 1000cc injectors, your gas mileage should be the same when you are out of wide open throttle.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
