Injen 17hp/16tq???
Old Feb 15, 2009 | 10:18 PM
ajjaro's Avatar
Injen 17hp/16tq???
has anyone dynoed their injen intake? how much power do they really produce?
Old Feb 15, 2009 | 10:19 PM
RedEcotecSS's Avatar
Skip it and get a RAW intake if your really wanting to make power
Old Feb 15, 2009 | 10:20 PM
jvc06sc's Avatar
I have no dynos or proof but at best 5-6hp
Old Feb 15, 2009 | 10:27 PM
ajjaro's Avatar
how much power does raw make?
Old Feb 15, 2009 | 10:30 PM
Check out their website. I THINK they posted dyno sheets... http://www.rebelautoworxs.ca/index/
Old Feb 15, 2009 | 10:31 PM
ajjaro's Avatar
the link doesnt work, how much power did it add to the wheels?
Old Feb 15, 2009 | 10:35 PM
jeanbalt's Avatar
no - 10 and that's a stretch
but the car sounds amazing
because the supercharger isnt muffled by the stock airbox
Old Feb 15, 2009 | 10:41 PM
car_guy_09's Avatar
Your going to see pretty much the same gains with any good name brand intake, As stated get the raw or what for OTTP's new intake because they are Stainless steel, Not aluminum, Problem with the aluminum ones are they get holes rubbed in them, I have an injen and its nice and all but its almost rubbed through in a few spots so il probably upgrade to a stainless one
Old Feb 15, 2009 | 10:43 PM
ajjaro's Avatar
either way im going to wait 3 weeks for dyno results from the ottp intake, does raw produce more power than injen? can injen be bought stainless steel?
Old Feb 15, 2009 | 10:52 PM
car_guy_09's Avatar
Injen cant be bought as stainless...
Like i said the most you will see is like 1whp difference at most between intakes. The only stainless intakes are RD fabs, Raw, And OTTP (soon).
Now if you plan to go to a smaller pulley you may see gains with a 3'' over a 2.75'', All the stainless ones are 3'', Im not sure if there are any aluminum 3'' intakes or not but im pretty sure the injen is 2.75''
Old Feb 15, 2009 | 10:55 PM
ajjaro's Avatar
eventually ill have a 2.5 pulley, probably by may
Old Feb 15, 2009 | 11:02 PM
car_guy_09's Avatar
Go 3'', So in other words stainless
Old Feb 16, 2009 | 12:41 AM
blacksssc06's Avatar
Well when I had my injen intake on and at 15 psi and with copper core plugs and a cherry bomb for a exhaust I made 220 to the front wheels I hope that kinda answers you. this was on stock computer with the boost mod. So just do the math lol
Old Feb 16, 2009 | 12:59 AM
Hockeyman's Avatar
keep in mind the gains aren't peak hp, but somewhere else in the powerband that saw the most gains.
Old Feb 16, 2009 | 01:08 AM
Originally Posted by Hockeyman
keep in mine the gains aren't peak hp, but somewhere else in the powerband that saw the most gains.
True that
Old Feb 16, 2009 | 01:19 AM
blk ss/sc 1's Avatar
ottp is comin out with an intake??
Old Feb 16, 2009 | 10:10 AM
Yup I think 3 inch
Old Feb 16, 2009 | 11:09 AM
Rippin07's Avatar
Lets just say this, I have dynoed my car with the stock intake, Removed the lower housing (aka air box mod) and finally with the injen, without touching the tune there is minimal difference in the air box mod from stock (keep in mind I just removed the lower section and didnt cut the **** out of it as I want to keep it pristine.) The injen showed power throughout the entire rpm range. After retuning the MAF for the Injen, power went up a little more. I dont post dyno numbers on this as its all bs to the AB mod guys because they feel the difference and Im lying. All dyno runs were performed on the same day. As for total gains, as said above the gains were more impressive throughout the rpm range and not at peak power.
On installation problems with the injen, I took a length of windshield washer hose, split it lengthwise and used weather strip adhesive on it, then take the split end and push it over the sharp edges around the hole that the intake will go through, position intake correctly and tighten, after two years the intake looks brand new and there are no wear marks on the tube at all. If you are fussy like myself the hole will look like it is surrounded by a factory gasket.
Old Feb 17, 2009 | 11:16 AM
hossdeuce's Avatar
so im not the only one with a cherry bomb
Old Feb 17, 2009 | 01:09 PM
LOL 0.4hp with cherry bomb hahaha
Old Feb 17, 2009 | 01:11 PM
PinaSS's Avatar
you cant go wrong with raw. Looks awesome under the hood and sounds great.
Old Feb 17, 2009 | 01:38 PM
how do you get one the site is not up i really want one
Old Feb 17, 2009 | 01:52 PM
ajjaro's Avatar
ill wait until i see ottp's dyno results to get an intake, their intake comes out in 3 weeks, i think it will be better than the raw intake, on top of that i like their service
Old Feb 17, 2009 | 02:42 PM
Hmmmm can't wait
717ssbalt
Oct 2, 2015 04:01 PM
jmelton327
Sep 25, 2015 09:44 AM
irvin316
Sep 25, 2015 12:41 AM
budah93
Sep 23, 2015 02:26 PM
