Install pics and directions for the SnowPerformance kit
Old 07-27-2006, 11:37 AM
  #51
SnowTech.3's Avatar
Originally Posted by 1fstss
what would happen if i spray nitrous and meth? im already spraying nitrous, and i know thats cooling it, would the 2 mixing togeather be bad?
They actually work great together. Many people use nitrous with water-meth for the octane properties, so they don't have to retard the ignition (at all or nearly as much) when they spray.
Old 07-27-2006, 11:42 AM
  #52
pierre's Avatar
Originally Posted by FAST06SS
Actually it is well north of 350F if you kept it there but thankfully since our engines rev so fast, we are only at the 'critical' point for a split second.
My point??
Have you measured it? I have not myself. Using M-62 gen 4 published delta temperature curves assuming 20 PSI, 18,000 RPM and 80 degree ambiant I get 330-340 F. I had to do some extrapolation because the curves don't go that high. Some folks with non functioning intercoolers and small pulleys have reported AIT2's of 300 F.
Pierre
Old 07-27-2006, 12:19 PM
  #53
FAST06SS's Avatar
Pierre
No, I have not personally measured it myself. My data came from the engineer who designed the IC and air intake for the LSJ. So if he is wrong, then so am I. Fair enough? Either way, keeping a 300deg outlet temp below 120deg on a hot summer day w/o ICE will be a tough feat.
Old 07-27-2006, 12:41 PM
  #54
pierre's Avatar
Fair enough.... 130 F AIT2 on an 80 F day is about the best I'd expect to see with the HE's alone currently being tested although there may be some gains to be had with a higher volume pump. Not a bad reduction though considering the cost.
Pierre
Old 07-30-2006, 06:42 PM
  #55
mattyfinch's Avatar
you guys seem to miss the second amazing attribute to the system... on normal pump gas, u can effectively add timing without knock to ur car roughly equivilent to what u would run with 116 octane race gas....the gains are 2 sided, with a cooler setup, and better burning setup combined.
Old 07-30-2006, 07:47 PM
  #56
vandy0419's Avatar
Umm...Rob already mentioned that. Did you read the whole thread even?
Just made 3 passes at the track, 86deg, DA 3340ft !! 2.0 60's went 13.2 13.0.13.3 at 106-107. All my buddies cars were off about .2-.3 and 2-3 mph as well.
Good news was how the WI worked Starting IAT2 was 118 each pass and each pass ended at 154, only a 36 degree rise on a STOCK IC set-up! Now add a second HE and i can see maybe 15-20 degree total rise. On these SC's that is INCREDIBLE!
92octane gas, 18-19psi boost, 24-25deg timing and no KR! Simply awesome!!
Old 08-26-2006, 05:26 PM
  #57
Blown 4-banger's Avatar
I don't know if someone has asked this yet, but can you run water/meth injection with the stock maf, or so you have to get an lt1 maf?
Old 08-26-2006, 05:50 PM
  #58
SilverSS/SC's Avatar
You dont need a LT1 maf to this . The stock Maf is fine just and will interface withe snow kit as well .
Old 08-26-2006, 05:53 PM
  #59
Sweet! Now, about the cost... does anyone want to buy a slightly used kidney?
Old 08-26-2006, 06:00 PM
  #60
meister's Avatar
www.steeda.ca sells the snow kit and we ship to the US from the US
Old 08-26-2006, 09:17 PM
  #61
06blackg85ss's Avatar
cobalt-addiction has em to with free shipping til the end of the month for the first ten kits
Old 08-26-2006, 09:29 PM
  #62
meister's Avatar
We are $40.00 cheaper ....shipping anywhere in the US would not be $40.00....
http://www.steeda.ca/catalogue_product_type_902.asp
When ordering, please put CobaltSS.net in the special request field
Old 08-27-2006, 02:09 PM
  #63
I don't know about you guys, but $400 is a little outta my price range (at the moment)
Old 08-27-2006, 02:26 PM
  #64
is that for the stg2 gm kit with the maft?
Old 08-27-2006, 05:38 PM
  #65
djt81185's Avatar
i just picked up a meth kit for 290 shipped...digital progressively controlled without a tank...w00t...after i install and test i'll detail the kit
Old 08-27-2006, 09:23 PM
  #66
good **** man..
Old 08-27-2006, 09:51 PM
  #67
Where did you get it?
Old 09-04-2006, 04:19 AM
  #68
darrend3's Avatar
[QUOTE=FAST06SS 92octane gas, [/QUOTE]
thats the most impressive part is that your running the fastest cobalt on a airbox mod and 92 octane
Old 09-04-2006, 11:46 AM
  #69
umm... he has a LT1 mass air sensor and 3.5" intake piping... plus a whole bunch of other bolt ons....
Old 03-12-2007, 01:17 PM
  #70
SnowTech.3's Avatar
I have info about the GM Stage 2 MAF kit to update - we incorporated the GM Hz translator inside the MAF control box for easier installation and wiring setup.
We are posting dyno results on the website if anyone would like to offer up their before-after dynos. www.snowperformance.net
Old 03-12-2007, 01:21 PM
  #71
well just for info purposes.. my 2.5 60lb tune on pump gas with meth injection I was running 25-26 degrees of timing with zero knock... car was an animal.
most parts are stripped off the car at the moment due to turbo swap going down soon. but the meth kit will def be going back in, high boost mode on pump is the best
Old 03-12-2007, 08:05 PM
  #72
mezzanno's Avatar
you think my car will put anywhere close to the power you put down?
Old 03-12-2007, 08:08 PM
  #73
without meth you should still be up in the high 270's maybe 280's but the low end is gonna be crazy
Old 05-01-2007, 11:24 PM
  #74
brifriinc's Avatar
Here is a link to the 'BETA' install pictures and directions. Any questions feel free to ask. I will be going to the track tonight in high temps to do some testing. Will post later. So far i am VERY satisfied with this kit!!
Rob
http://hoosierperformance.com/uploads/SnowInstall.doc
If that one doesn't work try this one and click on the appropriate tab,
I can't seem to get get these links to work. Can anyone copy and paste the contents for me or at least make it a different kind of file so I can read it? Thanks.
Old 05-02-2007, 01:20 PM
  #75
brifriinc's Avatar
Bump, Can anyone help me here?
Quick Reply: Install pics and directions for the SnowPerformance kit
