Installation question on Injen CAI for 2.0L
Before buying the injen CAI, i looked at the direction online, and it says PROFESSIONAL INSTALLATION STRONGLY RECOMMENDED. Those who have the Injen CAI, did you install it yourself or get a technician to? Also, do you recommend buying the hydroshield for it too? Thanks a lot
headlight is the easiest way. hydro shield isnt needed but if your car is lowered or sometimes have high water in your area u might wanna get one. but if ur gonna use your car for a boat ur gonna have problems anyway...
haha ok thanks. i'm gonna go ahead and order it, and if i have problems, i'll let y'all know. thanks a lot everyone
I've got an 07 and I just installed it last weekend with no problems whatsoever just make sure you do put the included vinyl trim on, around the mounting hole. If you are buying it get it from TTR they have the best customer service and I got mine within a couple days. Hope this helps!
TTR sells it also just go under air management its $29.99 so itll be like $275 Shipped but its well worth it. Try to pm Aaron and see what kind of deal you can get, they have something going on!
i did mine by removing wheel and only partially removing the fender well skirt. I removed all the front screws and bottom ones and then bent the skirt back behind the rotor and it stayed there and was really really alot easier to get back on after install.... great how to written up on it. dont follow instructions that come with it use the how to thats in this forum.
