Installation question on Injen CAI for 2.0L
Old Jan 5, 2009 | 08:15 PM
sscobalt205's Avatar
Question Installation question on Injen CAI for 2.0L
Before buying the injen CAI, i looked at the direction online, and it says PROFESSIONAL INSTALLATION STRONGLY RECOMMENDED. Those who have the Injen CAI, did you install it yourself or get a technician to? Also, do you recommend buying the hydroshield for it too? Thanks a lot
Old Jan 5, 2009 | 08:16 PM
1badBlueberrySC's Avatar
No you can do it... take the drivers side wheel off, remove the fender shroud (wheel well covers) and wallah it's all open...
Should take no more than an hour or so!
Old Jan 5, 2009 | 08:17 PM
sport08's Avatar
i dont have the 2.0 but there are Many people on here who have it and installed it themselves and i would recommend the hydro shield.
Old Jan 5, 2009 | 08:20 PM
scott allen's Avatar
Thumbs up
Dude a 12 year old can do it.Dont cut your self short its real easy. Also dont listen to the instructions ,it tells you that you have to remove the front bumper.Thats bull ****.
Old Jan 5, 2009 | 08:25 PM
OniMirage's Avatar
just remember that the rubber screw thingy is gonna be a BITCH to get all the way on that's technically the only hard part oh and don't lose any parts
SSdan's Avatar
I did mine differently. Threw the headlight opening
Old Jan 5, 2009 | 08:29 PM
Black SS/SC 06's Avatar
Either way works. I took the wheel off and removed the fender lining as well.
Old Jan 5, 2009 | 08:31 PM
StevesBlack06's Avatar
headlight is the easiest way. hydro shield isnt needed but if your car is lowered or sometimes have high water in your area u might wanna get one. but if ur gonna use your car for a boat ur gonna have problems anyway...
Old Jan 5, 2009 | 08:47 PM
haha ok thanks. i'm gonna go ahead and order it, and if i have problems, i'll let y'all know. thanks a lot everyone
Old Jan 5, 2009 | 08:52 PM
07BaltSS/SC's Avatar
I've got an 07 and I just installed it last weekend with no problems whatsoever just make sure you do put the included vinyl trim on, around the mounting hole. If you are buying it get it from TTR they have the best customer service and I got mine within a couple days. Hope this helps!
Old Jan 5, 2009 | 08:59 PM
yeah i'm thinking about buying it from there, but i wanna get the hydro shield and ive only seen it at injenairintakes.com. with that its like 275 and from TTR it would cost me 245 without it.
Old Jan 5, 2009 | 09:10 PM
TTR sells it also just go under air management its $29.99 so itll be like $275 Shipped but its well worth it. Try to pm Aaron and see what kind of deal you can get, they have something going on!
Old May 14, 2009 | 08:37 PM
ajjaro's Avatar
im putting my intake on in 5 minutes, what im gonna do is remove the driver side wheel, remove the fender lining and the headlight and put it in, is that the best way?
Old May 15, 2009 | 08:50 PM
stew_pidaso59's Avatar
i did mine by removing wheel and only partially removing the fender well skirt. I removed all the front screws and bottom ones and then bent the skirt back behind the rotor and it stayed there and was really really alot easier to get back on after install.... great how to written up on it. dont follow instructions that come with it use the how to thats in this forum.
Old Jun 28, 2009 | 03:39 PM
steven2008ss's Avatar
sorry to brin back an old post, but you can take the headlight off and do it with out taking the wheel off?
Old Jun 28, 2009 | 04:15 PM
sput's Avatar
Yeah. I installed mine this way. Take the headlight out (2 bolts) and the little frame beneath it (another 2 bolts)
brandon04
Oct 21, 2015 07:04 AM
717ssbalt
Oct 2, 2015 04:01 PM
justinchinn
Oct 2, 2015 12:18 PM
Bohb
Sep 27, 2015 09:11 PM
jas09ss
Sep 26, 2015 01:06 PM
