Installed Intense 3" pulley - I have a ?
Old Jun 24, 2006 | 02:49 PM
MarcS's Avatar
The Stig
Just got the pulley on and went for a ride. It really makes a difference. It felt very similar to when I drive the srt4 the way the boost comes on.
I have a question though:
I pressed the hub on without the pulley ring. I made the hub flush but when I attached the pulley, it has a slight offset from the shaft. I put the belt on and it seems to align okay but I'm not sure what effect this will cause. Anyone else have it installed this way, or should the pulley ring face be flush with the end of the shaft?
Old Jun 24, 2006 | 04:23 PM
JCswoosher2's Avatar
lol i just got my Intense Stage 3 installed. im not to much impressed. but then again my Supercharger pulley went flying off going down the Highway. so maybe i didnt get enough of a full feel. make sure its on there good.
Old Jun 24, 2006 | 04:30 PM
MarcS's Avatar
The Stig
I just read that post
I did a few runs with mine down the street and it felt great (3" pulley only), but then the neighbor wanted to kill me so I had to stop.
Old Jun 24, 2006 | 04:45 PM
MarcS's Avatar
The Stig
heres a picture for better refrence
I noticed when I started it up there was a lot of rattling. I turned the car off and found the screws that hold the pulley ring on had gotten loose. I remember reading something similar happened to zinner when he did his swap. They have to be VERY TIGHT which is something I learned
Old Jun 24, 2006 | 05:08 PM
jmartinez's Avatar
pulley should be flush with rod that turn the blades the part you pressed the hub on.i have the intense 3 with a 2.7 and the thing is a freakin beast more to come
Old Jun 24, 2006 | 05:10 PM
jmartinez's Avatar
and for the pulley falling off i used a dab of gm red lock tight no problem with the pulley
Old Jun 24, 2006 | 05:16 PM
MarcS's Avatar
The Stig
I took a drive with it and it seems to be fine with it in that position. The belt doesn't wear and it doesnt jump threads so I think I'll leave it. Otherwise I'll have to take it all apart again
Old Jun 24, 2006 | 06:16 PM
Matty's Avatar
Doesn't look flush in the pic.
The end of the hub should be flush with the end of the spindle/ snout.
Old Jun 24, 2006 | 06:18 PM
MarcS's Avatar
The Stig
Yeah, the hub is flush, but the pulley when its mounted sits out a little.
Old Jun 24, 2006 | 06:19 PM
Matty's Avatar
I just went out and looked at mine at it looks the same. I didn't look at the lip of the ring after the install.
Old Jun 24, 2006 | 07:00 PM
MarcS's Avatar
The Stig
I was just concerned about it being offset like that but if it's working for you then I'm not too woried. Thanks
Old Jun 24, 2006 | 07:03 PM
Matty's Avatar
Y/W.
Oct 20, 2015 09:56 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
