Installed Nates 2.9
Old Jan 16, 2008 | 05:39 PM
OverbooSSt's Avatar
Exclamation Installed Nates 2.9
So I finnaly put in my 2.9, inital impression was week, i did not see much difference at all, after a little while driving it i notice alot more low end torque, the car will spin 2nd accelerating from 30 to 70 est (the pavement is cold) at least i know theres no lack of power.
Question: I couldnt tighten the pulley bolts very much because the pulley would turn on me, they are nice and snug though, are they ok like that or do they need to be in very tight? Also did i need to put lock tight on these?
Old Jan 16, 2008 | 05:43 PM
OntarioBalt's Avatar
I got mine in the mail....I guess there's no reason to get too excited...lol
Old Jan 16, 2008 | 05:44 PM
KillerBee's Avatar
When i put my nates 2.9 on i noticed pretty good gains for 55 bucks boost faster and hit another psi or 2
Old Jan 16, 2008 | 06:53 PM
OverbooSSt's Avatar
anyone know how tight the pulley bolts should be???
Old Jan 16, 2008 | 06:56 PM
D4u2s0t's Avatar
i'll check the torqe rating later when i get home if no one else replies by then.
Old Jan 16, 2008 | 07:02 PM
06_SS_S/C's Avatar
I had the same problem as you, I just got them as tight as I could and put just a little bit of loctite on there and have had no problems, been 5 or 6 months now.
Old Jan 16, 2008 | 07:05 PM
rnjmur's Avatar
The SC pulley bolt torque is 15 lbs/ft. That isn't much, so as long as you have them nice and snug you should be fine.
You shouldn't use Loctite... you will have a bitch of a time ever trying to get the bolts back out...
Old Jan 16, 2008 | 07:08 PM
06_SS_S/C's Avatar
I said a little loctite, I have already taken them off and put back on with no problems.
Old Jan 16, 2008 | 07:20 PM
rnjmur's Avatar
That is good... you hear some horror stories about guys who can't get their pulley bolts out because loctitie was used when putting the bolts in.
Old Jan 16, 2008 | 08:25 PM
06_SS_S/C's Avatar
I couldn't get the stage 2 bolts out put in by the dealer, they uses gobs of loctite and torqued the hell out of those!
Old Jan 16, 2008 | 08:28 PM
D4u2s0t's Avatar
and maybe you were expecting too much? how much is a 2.9 going to give you over a stage 2 pully, MAYBE 10 hp? and i don't care what anyone says, it's not easy to feel the difference between 230 and 238 hp.
Old Jan 16, 2008 | 08:41 PM
SS33's Avatar
But TQ is felt more than peak HP,
And IMHO the main difference is how quick the boost is built.
Granted I have a 2.8, in the summers, but I can feel a huge difference when I switch back and forth in the low and mid range, the boost hits much quicker and builds smoothly til redline.
So even though peak HP numbers may not jump drastically, you have alot more 'usable' HP and torque for daily driving. I don't like to /rarely have the opportunity to go WOT for the majority of my driving
Old Jan 16, 2008 | 11:56 PM
dylaNNN's Avatar
anyone have a 2.9 for sale? :P
Old Jan 17, 2008 | 12:03 AM
Super_SS's Avatar
i got a damaged 2.9 for sale..long story short,it went on and off the car about 10 times in the past 2 months
Old Jan 17, 2008 | 12:16 AM
CREW54's Avatar
Where are you guys getting the Nates 2.9...I am going to order a S2 AGAIN..next week......Last time I got screwed by the E-Bay ******* "1Fastlittlefag" or whatever. Anyway, might as well get the 2.9 at the same time.
Thanks
Old Jan 17, 2008 | 12:19 AM
06_SS_S/C's Avatar
He has an ebay store, just search for cobalt pulley, its under the ebay store listings...or you can just PM him.
Old Jan 17, 2008 | 12:20 AM
kwest's Avatar
Yea thats my story. Dealer waay overtightened them and I have tried everything there is to get them off and even stripped one of the bolts. I have never seen something screwed in so tight before. I was told that if you use a torch to heat up the bolts that it would loosen up the locktite, so i held a propane torch there for like 2 minutes and tried it and the adapter that came with stage 2 to get the bolts on with broke in pieces.....so now i dont know what to do
Old Jan 17, 2008 | 12:22 AM
CREW54's Avatar
Thanks
Super_SS's Avatar
trq gun is ur friend buddy...i have one on the compressor,took my bolts off in 10 mins..and they had loctite on it,but its no match for my 200 bux trq gun
Old Jan 17, 2008 | 12:25 AM
anthonyS88's Avatar
hold the pulley with a strap wrench and torque accordingly
Old Jan 17, 2008 | 12:31 AM
kwest's Avatar
I tried using a crow bar to stop the pulling rotating and then putting the bolt adapter on a impact off a big ass compressor and it still didnt come off.
Old Jan 17, 2008 | 12:32 AM
anthonyS88's Avatar
i couldent get my 3/8 impact gun to fit in there. so i held the pulley with a fat ass strap wrench, and took my 14 inch long snap on ratchet and it came off like a snap
Old Jan 17, 2008 | 10:51 AM
OverbooSSt's Avatar
Originally Posted by CREW54
Thanks
He prefers if you just PM Him and then do it straight over pay pal
Props to Nate from me for a great seller and maker of this product, it was quick and painless!
Old Jan 17, 2008 | 11:18 AM
BoostingSS's Avatar
Hey If you dont want to mess with ebay you can buy direct from nate at, www.smoothflowpulleys.com. awesome product by the way!
Old Jan 17, 2008 | 11:38 AM
CREW54's Avatar
Thanks guys. Nate Pm'd me and explained everything.
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
