Installing LNF Mounts
Old Apr 10, 2012 | 11:41 PM
05RLS2's Avatar
I am going to be swapping out the stock LSJ mounts for the front and rear LNF trans mounts. I went ahead and put the car on stands for tonight and looked underneath to see it'll take to get them out. The front mount looks simple and straightforward. The rear one seems like it may take a little work getting out, not much room to manuver and the shift cables are literally sitting on the mount it seems. I looked at the how to articles for the rotated mounts, and some mention taking off the rear trans mounting bracket. Is this really necessary when replacing with a stock LSJ or LNF rear trans mount? Anyone here swap to LNF mounts and could tell me the process the used for getting the rear out?
Old Apr 11, 2012 | 12:16 AM
mrbelvedere's Avatar
it isent a hard job to do ur just over thinking things my advice is just get to doing it
Old Apr 11, 2012 | 03:10 AM
Vander Nars's Avatar
U should have gotten a spacer for the rear mount to rotate it aswell.
Old Apr 11, 2012 | 08:24 AM
05RLS2's Avatar
Probably. I saw the shift cable up there and didn't know if there was any other steps that had to be done first in order to get the mount out. I will mess with it later today
These are stock LNF mounts, not the rotated mounts
Old Apr 11, 2012 | 11:29 AM
i have a stock rear lnf mount with a spacer, the spacer is what makes it a rotated mount.
Old Apr 11, 2012 | 12:13 PM
Staged07SS's Avatar
Administrator
Administrator
Download the instructions off of CED's website.
I believe the instructions are for the LSJ wheel hop kit.
I used them for installing my GMPP (LNF) trans mounts back in the day.
Also, check out Powells how to. Even though these arent rotated they are a good deal firmer, and the 3 upper engine mount bolts should be loosened/re-torqued and allowed to settled.
https://www.cobaltss.net/forums/driv...el-hop-211475/
https://www.cobaltss.net/forums/driv...sj-lnf-253153/
Old Apr 14, 2012 | 03:45 AM
05RLS2's Avatar
I actually looked at both of those already, thanks anways. Plenty of good info in both links.
Well, there no possible way I can get the rear one out without removing the bracket or the shift cables (not touching these). The cables are sitting right above the mount where you can't slide it up and out. I tried wiggling it out every which way but it isn't going.
The front one is in but I left the rear alone for now. Since I can't find my push pin removal tool anywhere to take out the plastic pin holding the 02 sensor wiring to the rear trans bracket. I wish there was a way of getting the rear without taking off trans bracket, it'd save me from trying to find someone with a pin removal tool or haing to buy another
Old Apr 14, 2012 | 06:28 AM
SaberD's Avatar
i seem to recall needing to remove the upper bracket to install the rear lnf mount. there is also a small bracket holding the o2 sensor cable that i believe you have to remove. the shift cables are way far away, so you don't need to worry about those. make sure to support the engine.
Old Apr 14, 2012 | 06:37 AM
Powell Race Parts's Avatar
the xmas tree fastener for the o2 sensor is a pita without the forked removal tool. Yes undo and remove the entire bracket and re and re the rear mount off the car into the bracket. Once you undo the 3 lower bolts and the 3 tranmission mounts for the bracket, you can rotate the assembly and reach the 02 sensor easier to remove it and then extract the mount assembly. The cross bolt for the rear mount is torqued to 76 ft lbs/ the lower bolts are 37 ft lbs, the bracket to trans are 42 ft lbs. Be care ful and start all the bolts a few threads at the rear, the 3 trans mounts can be difficult if you tighten one bolt all the way up before the others.
Good luck
Old Apr 14, 2012 | 11:41 AM
05RLS2's Avatar
The SS must be different then. On my ION RL, the cables are running directly above the rear mount. So there is realy no way to push the mount up and out, I tried every possible way to wiggle it from under the car.
Good luck
Thanks. Kinda stinks that you have to take off the rear bracket to get the mount out, but its the only way to do it
bigdeertz
Nov 17, 2016 09:41 AM
deviance
Nov 24, 2015 05:51 PM
n20saturn
Sep 30, 2015 12:26 AM
Sep 27, 2015 08:53 PM
