GMPP Trans Mounts causing wheel hop ??
Old Apr 14, 2010 | 12:34 PM
Staged07SS's Avatar
Administrator
Administrator
Hey guys .... So over the winter I installed the GMPP Trans Mounts (SS/TC Mounts). Well, I'm experiencing wheel hop with them in 1st gear when rpms get around 6,500. When I had my production SS/SC trans mounts I never had wheel hop like this. I installed them as per the instructions, and torqued all bolts to spec. I even loosened the through bolts again last night, and torqued them back to spec to see if the trans needed to settle more. No dice. I don't think the addition of my Corsa catback increased my horsepower enough to cause wheel hop with upgraded mounts, ha. Any ideas on what may be causing the problem ?
I know some of you are going to say I should have bought the OTTP rotated mounts, but I really don't take my car to the track. All I was looking for was a slight upgrade over the production SS/SC trans mounts.
Oh yeah, I almost forgot .... I also have an Ingalls Torque Damper. It's been set at 10mm since I installed it a couple of years ago, and it has never caused a problem.
Old Apr 14, 2010 | 12:38 PM
BLAZIN07SS's Avatar
I'm too JDM for you
check your control arm bushings for damage and play
Old Apr 14, 2010 | 12:41 PM
Staged07SS's Avatar
Administrator
Administrator
I will look into that .... Thanks
Any other thoughts on what may cause this ??
Old Apr 14, 2010 | 01:00 PM
northvibe's Avatar
did you loosen the upper side passenger mount 3 bolts to let the engine realign and tighten them back to spec?
Old Apr 14, 2010 | 01:06 PM
Staged07SS's Avatar
Administrator
Administrator
Here's what the instructions from GM say to do (this is all from memory) ....
1. Install front trans mount and torque mounting bolts to 66 lb-ft.
2. Hand start through bolt (do not tighten)
3. Loosen rear trans mount through bolt to let transmission settle.
4. Tighten rear trans mount through bolt, and torque to 74 lb-ft.
5. Tighten front trans mount through bolt, and torque to 74 lb-ft.
You do the same procedure when installing the rear GMPP trans mount.
The wheel hop is driving me nuts, because I never had it with the stock SS/SC mounts. I always take my time when installing parts and tripple checked to insure i installed the mounts correctly.
Old Apr 14, 2010 | 05:50 PM
northvibe's Avatar
do what i said to do. :P
when I installed my ottp stage 1 kit, I had kinda bad vibes, John Powell told me to loosen the side passenger upper mount and retighten. WOW made a huge diff. I have barely a vibe and they havent broken in yet and It may be your same issue.
Old Apr 14, 2010 | 07:00 PM
Staged07SS's Avatar
Administrator
Administrator
Ok sounds good man !! Thanks for the tip
Sorry for misunderstanding what you were getting at. I bet you are right about the breaking in part as well. I have maybe 1,000 miles on them. I have to learn to be more paitent, ha.
Old Apr 14, 2010 | 08:34 PM
northvibe's Avatar
holy crap I bet after you loosen those mounts you'll feel a slight difference. Retighten to 45lbs (those 3 bolts) Only loosen them by 3/4 to 1 turn.
so loosen all 3 bolts then tighten all 3. You may not see the engine move but once you fire up the car you'll probably feel a slight difference.
Old Apr 15, 2010 | 07:25 AM
Staged07SS's Avatar
Administrator
Administrator
Thanks again man
I will be doing this after work today. I will let you know how I make out.
Old Apr 15, 2010 | 07:14 PM
Staged07SS's Avatar
Administrator
Administrator
Northvibe: This afternoon I loosened/re torqued the 3 bolts on the passenger side upper engine mount, and things seem to be better now. I'll be taking the car out tomorrow to test it out.
Old Apr 15, 2010 | 09:05 PM
northvibe's Avatar
woot woot
Old Apr 16, 2010 | 07:48 AM
Staged07SS's Avatar
Administrator
Administrator
woot woot
It worked man .... I opened the car up a bit on my way to work this morning, and I had zero wheel hop !!!! My shift light on my interceptor came on meaning I was at 7k rpm Thanks again for the great tip
Old Apr 16, 2010 | 11:33 AM
northvibe's Avatar
YA! for John Powell's tip
Glad to hear it
Old Apr 16, 2010 | 11:40 AM
JapEatr's Avatar
South Central *********
this fixed mine as well but i had them out of alignment for close to 3months, then drawmatic improvement
Old Apr 19, 2010 | 07:22 AM
Staged07SS's Avatar
Administrator
Administrator
Agreed man !! I can't believe GM doesn't include this important tip in their wheel hop kit instructions.
Old Mar 19, 2023 | 03:13 PM
Solaris99's Avatar
Bringing back an old thread to post my recent experience. I had installed the Powell stage 1 rotated trans mount back in 2015 and never dealt with vibrations like some have had. Then about a month ago I had the clutch replaced and it vibrated heavily afterward. The rotated trans mount wasn't stressed like the motor/trans got shifted to one side. So, I knew that wasn't the issue. I tried all different things with loosening bolts and driving lightly and then tightening again, but it didn't improve to where it was before. I thought it did at first and then I drove for a bit and I wasn't satisfied. What I ended up having to do was go through the entire process of bolt tightening with a jack under the trans like I was installing it for the first time, as John Powell says in this thread https://www.cobaltss.net/forums/driv...sj-lnf-253153/
GRok25
Nov 28, 2011 03:27 PM
Joemaster70
Apr 15, 2011 06:16 AM
Brenticus
Oct 1, 2010 06:32 PM
BCobaltSS
Dec 2, 2009 12:55 PM
Dunesk8r
Aug 4, 2009 02:39 PM
