Intake Problem and CEL?????
Old Apr 14, 2008 | 09:33 AM
Texas SS's Avatar
my CEL came on tyhe other day, scnned it at autozone it was a P0171 code "lean code" {installed for 750 miles }. well anyways later that day it went off when i did a hard pull in 2nd, went off near redline.
But next day i was driving and did a quick 2nd gear pull , got to top of 2nd then slowed down and my car did sometyhing weird
It felt as if my car was about to die and had no power it was just sluggish until i could get to a stop and at a stop it idled bad and sounded like i had a cam it would idle high then drop to low and almost shutoff. i shut/off restarted car and its fine hasnt done it again
do i need to clean the MAF sensor?
what is the problem? "besides intake code" or does it mean i need better sparkplugs?
Old Apr 14, 2008 | 09:41 AM
D4u2s0t's Avatar
check to make sure everything is on there tight. filter is still on, maf is in good, all connections are tight. make sure the filter is not wet. sometimes with the oiled filters, if they are a little over-oiled it will get on the maf and whack things out. a good maf cleaning can't hurt either.
Old Apr 14, 2008 | 09:47 AM
Texas SS's Avatar
will do but i was just mad cause ive had it on for 750 miles then outof nowhere it comes on then later it sounds like my car is cammed
Old Apr 14, 2008 | 09:52 AM
D4u2s0t's Avatar
well then it's very possible either something came loose, or your maf is dirty.
Old Apr 14, 2008 | 09:55 AM
originaladrian's Avatar
might have oil or something on the sensor, clean it. dosnt matter if ur car is new.
Old Apr 14, 2008 | 01:06 PM
Texas SS's Avatar
will do and not it seem like a WOT in 2nd it feels as if a belt is slipping or or something but i did change stiffness on Torqe dampner the other day to a softer setting so that may be it i guess
Old Apr 14, 2008 | 04:17 PM
flash13brandon's Avatar
ya make sure cai doesnt have any water inside it cuz i had a celica with cai and it got water in it and it was doing the same thing
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
OrangeCoba
Sep 25, 2015 06:06 PM
