Intake tune
Old May 2, 2013 | 03:55 PM
cOHbalt's Avatar
Intake tune
how much did it cost you to get the MAF to stop throwing codes due to an intake?
did you take it to a dealer to reflash it or did you do something else?
Old May 2, 2013 | 06:08 PM
Gelladuga69's Avatar
Custom tune.. Will cost in the couple hundreds, regardless.
Old May 2, 2013 | 06:21 PM
07ssBOOST's Avatar
its best to just go ahead get whatever mods you want on before you get it tuned or else you'll be doin it again
Old May 2, 2013 | 06:23 PM
Drunkship's Avatar
What kind of intake do you have? I bought my SS/SC with an Injen intake and it always threw a code. Switched to a ZZP intake and I haven't gotten a code yet. Also, make sure to disconnect to battery for 15 minutes before you start it up after installation.
Old May 2, 2013 | 06:52 PM
cOHbalt's Avatar
damn you spend ~200$ for the thing now you have too get it tuned for another ~200$
Old May 3, 2013 | 08:57 AM
Yeah, pretty much. Cheap route you can go is get the ZZP 1.0 PCM. That's like $100 and it's like a canned tune that will support your intake.
http://shop.zzperformance.com/store/...P-1-0-PCM.aspx
Old May 3, 2013 | 12:31 PM
coolbalt1's Avatar
Just get all your mods together without installing them. Once u get them all install, tune, be happy
Old May 4, 2013 | 09:49 AM
cOHbalt's Avatar
ZZPerformance - ZZP 1.0 PCM #ZZ-LSJ10PCM
Tell me more about this PCM? I am stock as of now
Old May 4, 2013 | 05:55 PM
My RAW intake never threw any codes.
Also if you have to pay the same price for a tune regardless of whats been done since last time you might as well bend over and pull your pants down, cause your taking it right up the crap cutter.
Your initial tune is where the high dollar amount is spent, after that, minor tweaks as just an intake install should be no where close to another initial tune price.
But if thats the case, id buy a ton of stuff and put it on before re installing.
Also being said, I had my badmab header installed from my gmpp and retuned and got 11whp/11wtq.
Old May 4, 2013 | 08:07 PM
If you really want a cheap tune to get rid of your intake codes, that's it. Read through the description.
Old May 4, 2013 | 08:37 PM
07ssBOOST's Avatar
lol thats not always a sure thing, the zzp pcm tune, mine still threw codes for it, just suck it up get a real tune and be done w it
Old May 4, 2013 | 08:53 PM
Blairwolf's Avatar
Maybe see if there is someone in your area with hp tuners that might do it for a small fee. $200 Seems like a lot to pay just for an intake change.
Old May 4, 2013 | 08:58 PM
c0de7477's Avatar
you sure your intake has no leaks? if you had a decent leak in your intake, it would throw a code.. and even if you fix the leak and try to reset it by disconnecting the battery, it might not go away. you'll have to get it cleared. you could always try that. it shouldnt cost you anything.
this exact thing happened to me.
Old May 5, 2013 | 10:35 AM
cOHbalt's Avatar
Thanks for all the input guys. I have a zzp intake but I think I'll try to find leaks first and disconnect the battery again. If not ill get a real tune as needed
Old May 15, 2013 | 12:25 AM
roth's Avatar
damn ii just ordered a injen intake -_-
Supercharged06SS
Dec 11, 2022 04:47 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
