issue with fuel rail?
Old Jul 9, 2009 | 04:11 PM
Snakes709's Avatar
Ok so im installing my TVS Supercharger right now. When i was taking out the fuel rail so i can get the M62 out. I was trying to unbolt the big bolt (cant remember the size...22mm i think?)...anyways when i was trying to undo it the whole section came off the fuel rail. Is this fixable or do i need a new fuel rail? The bolt still hasnt come loose off the small fuel rail above it. The piece is in red.
Old Jul 9, 2009 | 04:38 PM
Gabi's Avatar
it is flexible, so you dont have to take that off
that thing turn around, just be careful and dont bent it
Old Jul 9, 2009 | 04:47 PM
Snakes709's Avatar
doesnt really answer my question...lol. That piece came right off the fuel rail, can it go back on or do i need a new fuel rail? It looks like u have to bend the 2 ends to get it to go back on and then bend them back but iiunno
Old Jul 9, 2009 | 06:21 PM
damien's Avatar
As long as it isn't leaking you are ok.
Old Jul 9, 2009 | 06:28 PM
Snakes709's Avatar
thats what im thinking, i got it back on but its loose..trying to use vice grips to squeeze the metal together, there is a blue o-ring hopefully it doesnt leek.
Old Jul 9, 2009 | 06:29 PM
drew1991sf's Avatar
y did u take it off anyways? u can take out the m62 w/o taking it off
Old Jul 9, 2009 | 06:42 PM
damien's Avatar
Yep, just turn the key to run but don't start. if it pours fuel(you'll know) then thats bad.
Next time, remove the stupid pos black cover over the fuel rail and remove the 2 bolts that hold the rail to the valve cover. pull the rail up a tiny bit to wiggle it around and get more room for whatever tool you're using to get to the allen heads.
Old Jul 9, 2009 | 06:50 PM
Snakes709's Avatar
i had to take the whole fuel rail out to get to the hex bolts on the m62...the wire to the fuel injectors was in the way and i couldnt get to it, before i just undid the big ass bolt on the fuel rail, which is what i tried to do, but it never came loose, instead the damn end to the fuel rail came off.
Old Jul 9, 2009 | 06:54 PM
drew1991sf's Avatar
dude just get an extension and take off the fuel rail cover. i have taken mine off 5times w/o having to do wat u did
Old Jul 9, 2009 | 07:00 PM
Snakes709's Avatar
the fuel rail is off, everything is off, the m62 is out and im just waiting for the slow ass postal service to get here with my TVS. Damn thing says "out for delivery" at 9:01am this morning, its now 5:00pm and still nothing.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
