Its gotta be the cold
Old Jan 4, 2008 | 01:49 PM
CobaltVenomSS's Avatar
2 days ago when it was about 50-65 degrees out i was gettin a little over 15 psi...but last night i was gettin close to 19 psi cause it was like 27 degrees out...
Old Jan 4, 2008 | 01:50 PM
They call me 'E''s Avatar
colder air = better air.
Old Jan 4, 2008 | 01:52 PM
yea but i posted a thread kinda like this awhile and people were saying i had a clogged cat or something
Old Jan 4, 2008 | 01:54 PM
Admiral Jedi's Avatar
lol, nope it's the cold.
Onyxd04Redline's Avatar
It's just the colder air
Old Jan 4, 2008 | 01:56 PM
ok thank u
Old Jan 4, 2008 | 01:59 PM
an0malous's Avatar
the difference between 90* in summer, and -30* in winter, is perhaps 1.5lbs of boost for me.
I dont know how your seeing 4lbs....thats alot for only dropping down to 30*
Old Jan 4, 2008 | 02:05 PM
Area47's Avatar
Rent me! per hour
innaccurate gauge reading
Old Jan 4, 2008 | 02:08 PM
an0malous's Avatar
on mine or his?
Old Jan 4, 2008 | 03:43 PM
Hockeyman's Avatar
i'd say innacurate gauge...i have the s3 pulley and i've never boosted that much and it's been almost the same weather in dallas and tyler.
Old Jan 4, 2008 | 04:12 PM
Formula96's Avatar
how often you in tyler?
Old Jan 4, 2008 | 04:40 PM
-Jayson-'s Avatar
something else is wrong with your car, sounds like a clogged cat. The cold air wont give you 4lbs of extra boost. I see maybe 1-1.5lbs of extra boost going from 80F to 0F. If your seeing that much extra boost, i would assume your guage is off or your having exhaust issues.
Old Jan 4, 2008 | 04:47 PM
LopsidedJester's Avatar
agreed, most i've seen for boost change is 1.5 lbs due to cold weather
Old Jan 4, 2008 | 05:26 PM
Area47's Avatar
Rent me! per hour
on mine or his?
his
some people are confused on how to read the gauge sometimes.
the lil marks are 1/4 readings. dunno.
Old Jan 4, 2008 | 06:10 PM
srowler9's Avatar
i live in Mn and the temp was 0. I left a thread on this a little while back. I have a stage 2 and max the psi at 15. In that nasty ass cold weather I maxed out about 16.5. It felt faster that is for sure. A 4 psi jump though is a lot. Something doesn't make sense here.
Old Jan 4, 2008 | 06:12 PM
Projekt's Avatar
**** venom im gonna kick u in the nuts if ur complaining about cold in texas..it gets to -30 C up here in winnipeg..
Old Jan 4, 2008 | 06:13 PM
DTM2188's Avatar
The most dramatic increase I saw with S2 in the cold weather was 2 psi, went from 15 to 17, so 4 psi sounds like a lot to me as well.
Old Jan 4, 2008 | 07:39 PM
rukkee's Avatar
Bad gauge or reading it wrong . It gets way colder up here and ive never seen close to those numbers on a smaller pulley even .
Old Jan 4, 2008 | 07:41 PM
an0malous's Avatar
you better hope its the gauge.
cuz if your pushing 19psi on stage 2.....your on the ragged edge....
Old Jan 4, 2008 | 07:42 PM
Super_SS's Avatar
i always max out the boost in cold or hot air...i replaced like 2 boost gauges
Old Jan 4, 2008 | 07:49 PM
SilverSS/SC's Avatar
On my mechanical boost guage Ive never seen more than 1 psi variance between extreme weather conditions .
Old Jan 4, 2008 | 07:50 PM
bgbearcatfan's Avatar
i got my boost way over 15 psi once, and was confused as hell until i realized the emergency brake was on
Old Jan 4, 2008 | 07:51 PM
KillerBee's Avatar
x2 clogged cats can make you build bigger booste becuase the air is not going throw your exhaust its building up so all the back pressure
toysareforboys
Nov 17, 2015 05:22 AM
roth
Sep 26, 2015 12:16 PM
OrangeCoba
Sep 25, 2015 06:06 PM
Sabon_SS
Sep 7, 2015 12:39 PM
