Knock retard ?
Old Nov 7, 2007 | 08:13 PM
TurboTommy's Avatar
Knock retard ?
I was just curious as to what others are seeing for knock retard amounts...I know 0 is preferred but what is an acceptable or common amount to see? On my LSJ with the w/i turned on I see about 0. With it turned off I see anywhere from 1.7 to 5 under load
Old Nov 7, 2007 | 08:16 PM
an0malous's Avatar
stage 2 is a pretty messy tune.
anything less than 94 octane and I saw knock with it.
if your on a custom tune and seeing knock....id be asking some very poignant questions to your tuner.
Old Nov 7, 2007 | 08:34 PM
twoods450's Avatar
its not nice to knock retards
Old Nov 8, 2007 | 01:50 AM
rob561's Avatar
^haHAHAHAHAHAHAHAHAHAHAHAHAhahahahahahahahahahahah ahAHAHAHAHAHAHAHAHAHAHAHA
Old Nov 8, 2007 | 02:08 AM
HunterKiller89's Avatar
i cracked up too
Old Nov 8, 2007 | 02:11 AM
lsjwannabe's Avatar
1~2 won't kill it but if you are getting knock throughout your gear your car is going to hate you. 5* is way to much you are tuned to aggressively or just keep your w/i on
Old Nov 8, 2007 | 07:58 AM
TurboTommy's Avatar
Well I think I'm questioning the acuracy of the interceptor gauge. I tried it again this morning....with or without the w/i when you get on it the gauge will randomly bounce around from sec to sec...I never get a steady climbing reading. The car runs and sounds fine. Could this be fake knock or just the acuracy of the gauge?
Old Nov 8, 2007 | 10:29 AM
distillion's Avatar
with my setup, i get soem knock when i lay on it, only in third, as the rpms climb the knock dosnt come back, i too am using an areoforce.
i added 110 octane gas lastnight and i got absolutley ZERO knock.
my a/f is good and my iat2s are good.
i think in my case anyways its due to too much timing in a certain area and the cooler weather, because a few months ago i was not knocking at all and was running 94 octane.
Old Nov 8, 2007 | 11:05 AM
syP's Avatar
syP
NO knock is "acceptable" knock.
Old Nov 8, 2007 | 11:15 AM
Doc's Avatar
Doc
true, the time you could see knock and it be acceptable is right after shifting into gear.
its called burst knock
Old Nov 8, 2007 | 11:38 AM
syP's Avatar
syP
again.. NO KNOCK is acceptable knock.
Knock is the engines way of telling you "Im hurting"
False knock, on the other hand, is a different story
Old Nov 8, 2007 | 11:40 AM
Raven SS's Avatar
running a custom tune and get anywheres between 1.3-7.5 degrees knock but i have to deal with shitty ass california 91
Old Nov 8, 2007 | 11:46 AM
memphisr24's Avatar
I used to get so much...then bought hptuners...I get none and run 12.7 a/f's wich I want to change soon lol...didn't think I can run that lean without knocking.
Old Nov 8, 2007 | 11:52 AM
Rangerondubz's Avatar
Im getting some knock but that is b/c the temperature went from 80-90 to 50-60 outside. Gotta datalog tonight and fix the problem
Old Nov 8, 2007 | 12:00 PM
Area47's Avatar
Rent me! per hour
toe in knock is a bitch.
there is a fine line between acceptable levels and retarded levels.
acceptable is more or less toe in/burst knock. with the tune i run, it happens. audible knock isn't good. not hearing the knock, but seeing it on the cancer gauge isn't always bad.
there is different things that cause it. solid mounts. {phantom knock is a bitch} toe in. wrong octane. too aggressive of a map. i get more knock at part throttle then i ever do at wot.
throttle transition points, blah blah blah.
you have a knock sensor for a reason. you can adjust how this sensor reacts as well.
Old Nov 8, 2007 | 12:32 PM
distillion's Avatar
another reason i put in 110 lastnight.
i was thinking due to the cooler temps here the poly was hardening on my tranny mounts, this happened with my side engine mount which resulted in me goin back with the stock mount and the engalls.
but to my suprise it wasnt the tranny mounts since after puttin in 110 i got no knock at all.
Old Nov 8, 2007 | 12:38 PM
Area47's Avatar
Rent me! per hour
i have enough foot control i can keep the kr at bay. with the solid mount, i can get rid off all knock period. but the car drives like ****, so i just leave it be.
Old Nov 8, 2007 | 12:45 PM
RedlineBrian's Avatar
So wait are you guys saying mounts will help reduce knock.
Old Nov 8, 2007 | 01:03 PM
Area47's Avatar
Rent me! per hour
uh nope. they will produce more phantom knock.
Old Nov 8, 2007 | 01:08 PM
OK then i definitely misunderstood. Thanks for the clarification.
Old Nov 8, 2007 | 01:14 PM
an0malous's Avatar
knock sensor basically detects knock by the vibration it senses due to pre-detonation.
so things that increase your vibs will cause false knock.
mostly during high load, or shifting in my experience.
when you get knock during a pull, not during/shortly after your shift....is the stuff you really dont want.
also, knock retard will show up on the gauge as the biggest number first,
and then slowly drop down till its zero again.
this is your engine showing you that its pulled X amount of timing due to knock, and then slowly feeding the timing back in to make sure it doesnt come back.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
How to Guide
57
Oct 15, 2015 11:56 AM
Tupp
Sep 30, 2015 08:18 PM
OrngBalt
Sep 16, 2015 07:45 PM
twilson380
Sep 14, 2015 10:52 AM
