Knock with Stage 2
Old Apr 27, 2006 | 10:15 AM
p7x's Avatar
p7x
Knock with Stage 2
Hope u guys can help. Yesterday and again today I have noticed knock. I went with a colder plug with a smaller gap to ensure things ran smoothly but now randomly I'll get knock. It'll happen and I'll listen for it and shut the car off wait and turn it back on and it will be gone.
What do u guys think?? Suggestions would be nice. I'm really worried about this.
Old Apr 27, 2006 | 10:20 AM
CTCOBALTSSS's Avatar
I don't know bro but what did you gap your plugs at? I gapped mine at .38 and I don't have a knock. Make sure your oil is full and throw a bottle of fuel system cleaner in your tank. Not enough oil is usually what makes the knock.
Old Apr 27, 2006 | 10:22 AM
p7x's Avatar
p7x
they're gapped at 0.037, this is confusing the **** out of me cuz I got the colder plug to avoid ***** like this. I'll check the oil.
Old Apr 27, 2006 | 10:38 AM
WJT DEMON's Avatar
I dont think you have knock. You won't get preignition or detonation at idle, only under load. Not sure what you're hearing though.
Old Apr 27, 2006 | 10:40 AM
cmj917's Avatar
I've recently installed the stage 2 kit, and my engine sounds somewhat different. Sorry to be a newb on this, but how can you tell when the engine is "knocking"? I understand what it is, but, for lack of a better way of asking this, what does it sound like?
Also, would it should up on a scan tool, like the Interceptor from Aeroforce?
Thanks.
Old Apr 27, 2006 | 10:41 AM
p7x's Avatar
p7x
I was trying to decern between knock and sumtin else because I have never heard knock before. The engine runs fine, actaully runs very smooth, I only hear when I start the car and it's like it comes and goes.
The noise is like someone is tapping their knuckle on a woeden table.
Old Apr 27, 2006 | 10:44 AM
WJT DEMON's Avatar
Thanks.
sounds like a a rapid clicking under load.
Old Apr 27, 2006 | 10:45 AM
WJT DEMON's Avatar
thats not knock...I have had that too upon startup, but its not a cobalt thing. Its an every vehicle thing. Usually just the sound of the upper end of the engine before all the oil gets there and warmed up. Valvetrain noise I am sure.
Old Apr 27, 2006 | 10:47 AM
p7x's Avatar
p7x
I hope so.......I'll keep you guys posted.
Old Apr 27, 2006 | 10:49 AM
ozcaN's Avatar
my equinox got htat too in the morning. like after 30 seconds i hear a knock then goes away. i think thier is a post about some "ghost knocking" somewhere on the forums. they explain it thier
Old Apr 27, 2006 | 10:50 AM
GeoChevyCobalt's Avatar
Ya I got that to. Valvetrain nois for sure. Once your wormed up it gose away right.
Old Apr 27, 2006 | 10:52 AM
WJT DEMON's Avatar
haha, yea the ghost knocking was exhaust expansion and contraction.
Old Apr 27, 2006 | 11:13 AM
1stbluSS's Avatar
p7x you may want to check the tensioner for the timing chain .... does the sound seem to be coming from the right side of the vehicle ? I had the same issue and it gradually got worse.... started soundling like a time bomb at idle..... it will be warrantied and is a known issue with these cars...
Old Apr 27, 2006 | 11:41 AM
BullDog71ss's Avatar
Take a couple of nuts and bolts and toss them in a food blender, the turn it on and walk into another room. If you take the actual sound of the blender's motor out of the picture, that's about what pinging sounds like.
Old Apr 27, 2006 | 12:06 PM
BLKSS's Avatar
I allway baby my car for the first 5 minutes of driving before I open her up. Once I peeled out of my street without letting it warm up and I got a bunch of white smoke out of it. Sure dosent like being cold..
Old Apr 27, 2006 | 12:17 PM
Tomtwtwtw's Avatar
Not sure if it was mentioned, but it may be worth checking the drive belt as well. It might have a little play in it. I doubt it would be the cause, but it can't hurt to check!
Old Apr 27, 2006 | 12:39 PM
WJT DEMON's Avatar
pop the hood, start it up cold and have a look and listen.
Old Apr 27, 2006 | 12:57 PM
2K5SS/SC?'s Avatar
Push the clutch in when you here it. If it goes away when you do that, start looking into a new clutch and TOB.
Old Apr 27, 2006 | 01:05 PM
Jmc007's Avatar
The ghost knocking is not engine detonation (not knock), is not exhaust neither a valve sound, it's the EVAP sytem in the gas tank, it makes a TOC TOC TOC sound like someone hammers the gas tank.
Old Apr 27, 2006 | 01:35 PM
p7x's Avatar
p7x
Realized now that its not knock......knock isnt actually a knocking sound more or an electrical sound, im going toward the route of valve train. I will try all the above mentioned and see what happens and let you guys know. thanx for the suggestions guys.
Old Apr 27, 2006 | 02:49 PM
zinner's Avatar
Moderator Alumni
Have you tried putting in the stock plugs? They are supposed to work with the stage 2
Old Apr 27, 2006 | 03:33 PM
p7x's Avatar
p7x
That was the plan since it started happening, I am going to wait until tmrw and if this problem persists i will put them in. Thanx.
Old Apr 27, 2006 | 04:06 PM
Xander9988's Avatar
This is not a knock, the 3400 and 3800 engines also get this (not sure about the new 3500 and 3900) and usually starts happening once the engine is broken in after a couple thousand miles. It fades after a minute or two of running, or revving the engine a few times makes it go away. I wouldn't worry about it, but if it concerns you that much bring it up with your dealer.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
HEATON
Oct 16, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
