Knocking Sound in Engine
Old Sep 11, 2011 | 07:15 PM
Powell Race Parts's Avatar
I put new tensioners in cars that come in, I just look at the nut if its thin and rusty I know its old and change it. All the new ones I have seen from Tom have a thicker nut with a groove in it although toms CED picture does not show this.
Old Sep 11, 2011 | 08:56 PM
nhanson's Avatar
Mr Belvedere is right. You are wrong. Ecotecs in good condition start and run quiet as a mouse. Great motors.
My motor is quiet except for one "bad" hydraulic lifter that ticks sometimes, it comes and goes and i just dont bother with it.
My ecto cavvy wintr btr is quiet as a mouse. Oh both motors have the new tensioner from CED its so cheap its silly not to run one.
cold starts yield valve noise. my engine is also perfect but still has valve noise on cold starts
Old Sep 11, 2011 | 11:39 PM
mrbelvedere's Avatar
trust me its not valve noise its your lash adjusters and they are on their way to out gm has done a revision on them what is happening is they are bleeding off overnight and when you fire the engine it takes time for them to repump up and quiet down basicly when the cam comes around to open the valves the lash adjuster is colapsing untill it gets repressurized by the oil pump
Old Sep 12, 2011 | 12:48 AM
kikal8's Avatar
the timing chain tensioner is the ticking noise in these motors 90% of the time. change the timing chain tensioner and recheck. its cheap so wont hurt. ud probobly have to replace it soon anyway. other than that these are well built motors ha. THANK U SAAB TECHNOLOGY!
Old Sep 12, 2011 | 07:33 AM
nhanson's Avatar
its done it since ive bought the car NEW
Old Sep 12, 2011 | 08:35 AM
i would thank opel if i was you they are the originator of the ecotec( it was called the family II) back in the late 70s
Old Sep 12, 2011 | 08:36 AM
you have a valve train problem and shouldve had it fixed under warranty
Old Sep 13, 2011 | 02:15 AM
killianss's Avatar
how much should i expect to pay at the dealer for this installed? got about 87k miles so it probably wouldnt hurt at this point.
Old Sep 13, 2011 | 09:36 PM
nhanson's Avatar
car sees daily WOT..bolt ons and tuned...0 problems
this only happens when its cold...loud valves
Old Sep 14, 2011 | 10:58 AM
user 72239's Avatar
Right on, well when you go WOT one day and you **** something up in your engine. I guess you will learn the hard way.
Old Sep 14, 2011 | 11:24 AM
  #36
Bika's Avatar
Fail Less.
This thread explains alot for me.
kthxbai.
Old Sep 14, 2011 | 03:56 PM
  #37
nhanson's Avatar
right...0 problems in 51k miles
Old Sep 14, 2011 | 08:48 PM
  #38
Black05's Avatar
0 problems in 66k miles, then I cracked a valve in half.
**** happens, retard
Old Sep 14, 2011 | 09:04 PM
  #39
nhanson's Avatar
that sucks for you
Old Sep 14, 2011 | 09:54 PM
  #40
Black05's Avatar
Yeah, it did. $1800, a new set of heads and valves, ARP studs and installation later, I learned my lesson the hard way. They aren't indestructible, and if ANY problem arises, no matter how simple, it should be taken care of immediately. Take care of the little things, and the big things take care of themselves.
The cause was a tune that needed attention after moving from Ohio to Alabama, and was leaning out. I didn't take care of it soon enough. I wasn't leaning badly either.
The point is, just because something hasn't happened yet, doesn't mean it won't happen later.
Old Sep 14, 2011 | 10:18 PM
  #41
nhanson's Avatar
oh i know...im just saying the problem they are saying i have isnt correct.
Old Sep 15, 2011 | 03:00 PM
  #42
Bika's Avatar
Fail Less.
Ok, need some clarification. The new tensioner needs released once threaded in? And what needs to be removed to install the tensioner? Reading some of the J-body forum posts they are tilting/pulling their whole engines to do the tensioner :-\
Old Sep 15, 2011 | 03:20 PM
  #43
on the ex side of the head unscrew the tensioner remove it screw the new one in you dont need to release anything
Old Sep 15, 2011 | 04:15 PM
  #44
Bika's Avatar
Fail Less.
that sounds easy enough
Sl0wbaltSS
Nov 21, 2018 11:11 PM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
