Lash adjusters
Old Feb 1, 2012 | 08:21 AM
07_Red_SS/SC's Avatar
Lash adjusters
Quick question for anyone running aftermarket cams, I am throwing in a set of ZZP Stg2 blower cams, 82# springs and ZZP's retainers. Before I get everything finished up should the stock lash adjusters be swapped or will they be fine with the higher lift from the stg2 cams? Anyone running stg2 cams have any problems I should address b4 I reassemble?
Old Feb 1, 2012 | 08:39 AM
mrbelvedere's Avatar
they will be fine
Old Feb 1, 2012 | 09:29 AM
Thanks
/thread
Old Feb 1, 2012 | 11:03 AM
05vue-redline-06ion's Avatar
I used stock adjusters with GMR cams and it did not work. The base circle was too small on the cam and the adjusters souls not adjust out enought. After putting the stock cams back in it I had to replaced the adjusters.
Not sure how similar the gmrs are vs the zzp stg2
Old Feb 1, 2012 | 11:09 AM
he dident ask about gmr cams
Old Feb 1, 2012 | 03:56 PM
Hence why I stated that I wasn't sure about how similar the stage 2 zzp cam profile is vs the gmr
But if he got his answer the he got his answer....
Old Feb 1, 2012 | 04:19 PM
zzp cams have a big enough base circle
SmitBag
Sep 7, 2016 08:05 AM
toysareforboys
Nov 17, 2015 05:22 AM
justinchinn
Oct 2, 2015 12:18 PM
The Rookie24
Sep 20, 2015 04:33 PM
brett.higgins3
Sep 14, 2015 01:48 PM
