Lean Bank 1
Lean Bank 1
I went to autozone and they said my car is running lean on bank one. So whats that should i buy spark plugs or run some injector cleaner or somthing here are my mods, Flow master muffler and intake mod.
Don't take the car to autozone....
Lots of people have been getting lean codes with CAI/exhaust...the likely cause of it is the injectors are pretty well maxed out from factory, and they are unable to keep up with the demand being placed upon them when you put a less restrictive intake / exhaust on the car. Stage 1 (and of course stage 2) will likely clear this up, as it includes larger injectors.
Originally Posted by Justinian
Bank 1?
The Cobalt only has one bank of cylinders. I mean, maybe they knew that, and just decided to refer to it as "bank 1," but it almost sounds like they didn't even lift up the hood.
I was getting the same code and I put a little bigger O rings on my oil dipstick and the code went away. My cousin works for chevy and he had his tech 2 hooked up and bank 1 was running high. When he pulled the dipstick out and put his thumb over the hole, bank 1 dropped down where it should be. He said that the extra air was getting in through there. I know it soulds weird but I was watching the gauge when he was doing all of this. You might want to check it out.
Originally Posted by Witt
Umm, Bank 1 as in 02 sensor. No, they didn't lift the hood, they plugged in an OBD2 scanner and read the Diagnostic Code.
Yes, I realize they read the code off an OBD2 scanner. I just never heard an O2 sensor called "bank 1." But ok, I guess.
I had alot of fun with my own Bank 1 lean code last week, I was interupted while changing my oil.
I didn't get my oilc cap on 100%, I got a lean code and when I lifted the hood to check on things I found a nice little oil slick.
Originally Posted by Rusty
in this case, where would one get a bigger o ring for the dipstick? and do you think that with 42.5lb/hr injectors, bad o rings there could be the culprit?
