Lean On Bank One Engine Code Please Help!!!
Old Aug 14, 2008 | 12:51 AM
bodykitredss's Avatar
lean on bank one
I keep on throwing a lean on bank one code not sure what the code is off the top of my head i was wondering what it could be from and how i can solve it. I just got back from iraq so my car sat for 13 months, but i have been through a few tanks of gas since if been back so i dont think it is the gas. I also installed new ngk plugs one step colder gapped at .45 in prep for my stage two. (stage two not installed yet). Also a megen catback exhaust, and a injen cold air intake if you guys have any suggestions im open to them. thanks I also forgot to mention that the code did not turn on right away it took about a day and a half to come on once i cleared it took about a day for it to come back on.
Old Aug 14, 2008 | 01:22 AM
theneelster's Avatar
From the intake. Almost always in my car.
Old Aug 14, 2008 | 01:26 AM
REIGN SS's Avatar
Original Hayden Fanatic
Threads merged, no reason for 2 of the exact same threads
Old Aug 14, 2008 | 01:36 AM
Sorry i tried to delete it i needed to add something and it wouldnt let me.
Old Aug 14, 2008 | 01:41 AM
scss's Avatar
i think its a O2 sensor
Old Aug 14, 2008 | 01:44 AM
Raven SS's Avatar
disable it..or get a tune
Old Aug 14, 2008 | 10:39 AM
Dainslaif's Avatar
Why are you running stage 2 plugs if you don't have it installed? Go back to stock plugs.
Also, try .040 when you do get it installed.
Old Aug 14, 2008 | 04:14 PM
Bika's Avatar
Fail Less.
colder plugs are not a bad thing on our stock set up. wont hurt a damn thing and should dissapate heat better than stock platinums.
but i agree, gap should be between .035 and .040
you most likely have p0171 lean fuel trim code. common thing from aftermarket intakes. a lil maf tuning will fix this minor problem.
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
