Lean On Bank One Engine Code Please Help!!!
lean on bank one
I keep on throwing a lean on bank one code not sure what the code is off the top of my head i was wondering what it could be from and how i can solve it. I just got back from iraq so my car sat for 13 months, but i have been through a few tanks of gas since if been back so i dont think it is the gas. I also installed new ngk plugs one step colder gapped at .45 in prep for my stage two. (stage two not installed yet). Also a megen catback exhaust, and a injen cold air intake if you guys have any suggestions im open to them. thanks I also forgot to mention that the code did not turn on right away it took about a day and a half to come on once i cleared it took about a day for it to come back on.
colder plugs are not a bad thing on our stock set up. wont hurt a damn thing and should dissapate heat better than stock platinums.
but i agree, gap should be between .035 and .040
you most likely have p0171 lean fuel trim code. common thing from aftermarket intakes. a lil maf tuning will fix this minor problem.
patooyee
Oct 1, 2015 01:07 PM
