loosing boost!
Old Jan 27, 2009 | 01:32 PM
OriGinaL Condo's Avatar
Originally Posted by usdm08
I really don't car I make the car run hard n if it blows, it's blow I take motor out n build it n come bak running harder
You don't sound like you know enough to build a motor.
Old Jan 27, 2009 | 01:54 PM
D4u2s0t's Avatar
you know nothing about modding a car. do some research before you mod next time. why worry about blowing a motor and re-building when it's easy to make what you have safe?
i'm kinda wondering if this is a joke... i know i'm giving the benefit of the doubt, but i don't think people are this dumb
Old Jan 27, 2009 | 02:39 PM
Bika's Avatar
Fail Less.
knock much? probly the ecu cutting boost because you are running alot of heat and are way too lean.
which 77.9 pulley is it? if its the one from cobalt addiction you are running a 2.79" pulley on stock injectors it only says "77.9" to maintain the look of a stage 2 pulley.
People have gotten away with a 3" pulley on stock tune/inj. its not unheard of. However its akin to begging for a cooked piston
Old Jan 27, 2009 | 02:48 PM
ShortStack's Avatar
i thought at firs the ECU was pulling boost...
esp it being stock.
Old Jan 27, 2009 | 02:57 PM
Bika's Avatar
Fail Less.
i was just looking at a b0ne stock 2006 ss/sc tune file and surprisingly found nothing that limits boost in 1st or 2nd gear. only traction control, electronic throttle control, COT, and IAT thresholds will cut boost.
Old Jan 27, 2009 | 02:59 PM
ShortStack's Avatar
Yea i didnt see anything either.. but... i wasnt sure if i was missing it or not
Old Jan 27, 2009 | 03:08 PM
BLAZIN07SS's Avatar
I'm too JDM for you
well it is due to the boost bypass valve, it is bleeding off boost. i actually know a guy in south florida running that set-up. car runs HARD for little mods. same was happening to him and he did the boost bypass mod to hold 15-16lbs. its not great for the car, but i have not seen an LSJ blow up with that set-up yet.
Old Jan 27, 2009 | 03:46 PM
OneCOLDBIZL272's Avatar
Nuthin is gonna happen to his car becuz I been running my car with 42 lb injectors on gm tune n a 2.7 pulleys n nitrous for about 2 years almost n my car runs fine n hard and I race my car like almost everyday.
now is that a reliable 2 year or, my **** went boom 2 times in the last two year im just not saying, wow, post when you blow that **** to the sky bro......
i love fourms and people who think they know what there doing........oopps did i just think out loud
Old Jan 27, 2009 | 04:24 PM
jonathan923's Avatar
yeah am running on the 77.9 pulley from gm is just that i didnt get the injectors. n well the car for little mods its running pretty hard but now i think that, that just might be the problem. the injectors. but since i dnt step in it as much maybe thats why nothing has ever been wrong with it. n its beign a while already since i have it that way. but when i installed my cold air thats when i started noticing the lost of boost.
Old Jan 27, 2009 | 04:25 PM
ShortStack's Avatar
Yes thats the car cutting flow.
Old Jan 27, 2009 | 04:30 PM
  #36
1badBlueberrySC's Avatar
You are truly ignorant... learn how to type!
Old Jan 27, 2009 | 04:31 PM
  #37
ShortStack's Avatar
i think we are done with that argument.
Old Jan 27, 2009 | 04:33 PM
  #38
I realize that... but when someone doesn't know what they are talking about, and then sounds like that it needs to be realized.
You are loosing boost between shifts? Check your tensioner... if it's loose you may be loosing boost due to belt slip!
Old Jan 27, 2009 | 05:12 PM
  #39
REIGN SS's Avatar
Original Hayden Fanatic
Stay on topic or stay out.
If you can't follow the rules and have to resort to name-calling/insults don't post.
Old Jan 27, 2009 | 05:13 PM
  #40
whats that come again i dont speak Ebonics
Old Jan 27, 2009 | 05:15 PM
  #41
As I said before all the BS... check your tensioner, if it's bad it will take tension off the belt causing slip!
Therefore loosing boost at higher RPMs
  #42
ShortStack's Avatar
*shakes head*
Old Jan 27, 2009 | 05:17 PM
  #43
hey ohla regin
im a go with blue berry i would check you tensioner first
Last edited by OneCOLDBIZL272; Jan 27, 2009 at 05:17 PM. Reason: Automerged Doublepost
Old Jan 27, 2009 | 07:02 PM
  #44
BLAZIN07SS's Avatar
I'm too JDM for you
Originally Posted by OneCOLDBIZL272
hey ohla regin
no it is the bypass valve bleeding off boost. the was a car with the same issue down in south florida. i bet money it is the bypass valve bleeding boost off
Old Jan 27, 2009 | 07:12 PM
  #45
SSdan's Avatar
Guaranteed it's the bypass valve. It's built into the stock tunes.
Old Jan 27, 2009 | 11:12 PM
  #46
Bika's Avatar
Fail Less.
If its built in to the tune, hptuners cant see it. theres nothing in the stock hpt file to limit boost except when its meeting one of the criterion for traction control, etc, cot, or iat boost limit the 1st and 2nd gear boost is set at or above 100% (somehow they set it at 200% which is unattainable once you change them you cant go over 100%)
Old Jan 28, 2009 | 12:30 AM
  #47
greenie899's Avatar
mine did the same thing take the CAI off it messes with the MAF you put the stock air box back on and do the air box mod you will be good again i tried everything to figure it out and as soon as i put the stock intake back on it fixed it
Old Apr 2, 2009 | 02:57 PM
  #48
after all this time...i saw that noone of you were right about this arguement...the only problem was the water pump which wasent pumpin water through the heat exchanger or anything. so the water wasent flowing throught the hoses...which also means that the car was runnin at very hot temperatures, after seen the logs before doin the proper tune thats how we found out. so if any of you get this same issue another choice to find solution would be checkin your water pumps. thanks anyways for replys based on this issue...now is running great with the help of a&L performance down here in miami after puttin the GM 42lb injectors headers and full 3" piping and a custom tune. thanks again and any coments let me kno.
turbochargedss2012
Sep 20, 2023 12:17 PM
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
Tupp
Sep 30, 2015 08:18 PM
jmelton327
Sep 26, 2015 10:04 PM
