Lsd?
Old Mar 9, 2008 | 01:50 AM
jvc06sc's Avatar
Lsd?
This is probably a very stupid question. I recently bought an 06 ss/sc without the g85 package and the sicker says that it doesnt have a limited slip. The other day i did a burn out and both tires smoked. I was under the impression that if you dont have lsd the car only pulls off one wheel but both mine spun so im kinda confused. like i said, most likely a stupid question, but any input would be appreciated.
Old Mar 9, 2008 | 01:53 AM
Sharkey's Avatar
a limited slip will give a 50/50 torque split, an open diff wont always. however, if you do a burnout right without an lsd, you can still get both tires spinning.
the big thing is cornering and heavy throttle. without an lsd, the inside tire will just spin, with an lsd it wont.
Old Mar 9, 2008 | 01:55 AM
FZWCobalt_09's Avatar
If it is the g85 package you have the lsd.
QFT.
Last edited by FZWCobalt_09; Mar 9, 2008 at 01:55 AM. Reason: Automerged Doublepost
Old Mar 9, 2008 | 01:56 AM
widebody_balt_ss's Avatar
no, you can spin both tires without lsd if you are going in a stright line.
Old Mar 9, 2008 | 03:08 AM
jvc06sc's Avatar
So in a drag race its not that big of an advantage to have an lsd. But if your coenering it is?
Old Mar 9, 2008 | 03:12 AM
Sharkey's Avatar
in drag racing it can be a concern. if you launch and the car loads to one side, one tire will start spinning, usualy the passenger side. when cornering its more important with the power levels on the ss/sc, as a slight roll on the throttle comming out of a corner is enough to break a tire loose.
its more important to have an lsd for performance driving/racing in a fwd, as they are very prone to tire spin from even light throttle inputs.
Old Mar 9, 2008 | 03:13 AM
that is mostly correct. it is more of an advantage in a road race to have lsd than in a drag race.
Old Mar 9, 2008 | 03:17 AM
ecotecon18s's Avatar
I have the open diff right now and on my last trip to the track after take off it was so hard to keep it in a straight line because it keep pulling back and forth...
it also has a bad habit of doing it on the street if I punch it in 2nd gear...
Old Mar 9, 2008 | 03:26 AM
KillerBee's Avatar
I dont have LSD on my cobalt and i can burn/smoke both tires LSD just puts 50/50 power to each wheel
Old Mar 9, 2008 | 03:27 AM
rocco11189's Avatar
Yea I dont have LSD and im fine without it.
Old Mar 9, 2008 | 03:36 AM
KillinKrullin's Avatar
i just bought an 07 new after they stopped the recaro seats..... how do i know if it has lsd? did that turn into standard equipment? in not is it in the vin# or what?
Old Mar 9, 2008 | 03:38 AM
KillerBee's Avatar
Yeah have the dealership run your vin or check out your window sticker on the car
Old Mar 9, 2008 | 03:40 AM
would it say on the window sticker? i have that somewhere. sorry bout the thread jacking
Old Mar 9, 2008 | 03:42 AM
KillerBee's Avatar
It should say it on the window sticker it has all the options your car came with but to be sure if you dont see it on there is to check your vin at the dealership see if its under your vin but should be on your window sticker
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
HEATON
Oct 16, 2015 07:21 PM
bigdogstokes16
Oct 8, 2015 10:28 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
importkiller
Sep 30, 2015 07:18 PM
