lsj block pitting
Old Feb 17, 2013 | 01:00 AM
gumby3558's Avatar
lsj block pitting
I had a number 2 cylinder dlown head gasket. I see pitting in the block surface but its strait as an arrow. Should i pull iy and get it resurfaced?
Old Feb 17, 2013 | 01:06 AM
c130aviator's Avatar
picture, and we can give you a better answer, are you running stock boost pressures, what are your plans for the car.
Old Feb 17, 2013 | 01:24 AM
Tjolley's Avatar
The ecote blocks r lost foam casted so they look pitted..
I believe the lsj head is sand casted someone correct me if im wrong. And i think the bed plate is sand casted also.
Old Feb 17, 2013 | 01:34 AM
head sand casted, block upper and lower lost foam.
Old Feb 17, 2013 | 01:53 AM
Tjolley's Avatar
Hmm ill take a closer look at my spare block but i thought it looked sand casted..
Old Feb 17, 2013 | 09:17 AM
you know now that I think about it, you are right, the lower section, the cradle is sand cast! sorry about that.
OP the deck of the block is what matters when the headgasket pops. We need to see a pick of the deck if you would like input on the pitting.
Old Feb 17, 2013 | 09:49 AM
mrbelvedere's Avatar
the deck of the head matters just as much as the deck of the block
Old Feb 17, 2013 | 04:26 PM
gumby3558's Avatar
here are my pictures my head is getting resurfaced
Old Feb 17, 2013 | 04:39 PM
Tjolley's Avatar
This is a close up of my zzp block
Old Feb 17, 2013 | 04:41 PM
true but the op only stated he was worried about the block, guessing he has no issues on the head.
Old Feb 17, 2013 | 04:46 PM
my mrbelvedere sleeved block
Freshly ported, 3-angle, decked head, ferrea valves, 82# springs, blah blah. I had this done at a diesel shop because they were the only ones with machines big enough for our 13" wide head.
Old Feb 17, 2013 | 05:20 PM
the block and head needs t be finished as fine as possible if it isent it wont hold a head gasket and do not use copper spray on the head gasket
Old Feb 17, 2013 | 05:22 PM
gumby3558's Avatar
what would cause that have a bad head gasket for awhile?
Old Feb 17, 2013 | 05:55 PM
mongorat427's Avatar
Planning on sleeving a gen 3 LHU block.
Old Feb 17, 2013 | 08:42 PM
gumby3558's Avatar
can the engine and trans be pulled out the to as a unit?
Old Feb 17, 2013 | 08:53 PM
TStone's Avatar
Top? I'm not sure
Most people drop it through th bottom
Old Feb 17, 2013 | 09:40 PM
gumby3558's Avatar
yea i don't really have the resources to that. god i wish i still worked at the dealer. but you got to go where the money is
Old Feb 17, 2013 | 09:46 PM
TStone's Avatar
I heard that.
But you can get the car high enough with a jack & stands to drop it out of the bottom
Old Feb 18, 2013 | 08:50 PM
Bluelightning's Avatar
Got Bewst?
LHU block doesn't have sleeves
Old Feb 18, 2013 | 09:10 PM
Dude drop it out the bottom, I did it with 4 6-ton jack stands 3 ton jack, 2x4's and a furniture dolly.
I reinstalled with a friends cherry picker but never used the crane portion of it for more than a second to sit it in the cradle. You dont need a cherry picker or anything else but the stuff I mentioned above.
Old Feb 18, 2013 | 11:34 PM
what you are seeing is due to the lost foam casting process and is normal
Old Feb 19, 2013 | 12:09 AM
gumby3558's Avatar
dude drop it out the bottom, i did it with 4 6-ton jack stands 3 ton jack, 2x4's and a furniture dolly.
I reinstalled with a friends cherry picker but never used the crane portion of it for more than a second to sit it in the cradle. You dont need a cherry picker or anything else but the stuff i mentioned above.
thats impressive!!!! Where theres a will theres a way lol
Old Feb 19, 2013 | 12:38 AM
i was motivated and alone, built the entire engine, car, etc by myself with some cash of course. Turned out ot make 420 very reliable horsepower, or so we shall see, its only been ran hard about 12 times so far.
if mrb ok's it I would think you wont have to pull that engine.
Last edited by c130aviator; Feb 19, 2013 at 12:38 AM. Reason: Automerged Doublepost
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Oct 13, 2015 09:32 PM
Trav3480
Oct 1, 2015 08:17 PM
