lsj build questions
Old Feb 8, 2013 | 02:07 AM
boostnbanana's Avatar
lsj build questions
ok so i'm currently rebuilding my engine for the second time. First time the engine blew a hole in the stock no1 piston at 13,000 miles. After chevy cancelled my warranty only for having a cold air intake i decided to rebuild myself. being young and on a budget, this is how the build went the first time. obviously i needed pistons so i purchased the diamond pistons from intense-racing.com along with new bearings, a cometic gasket, 2.8" pulley, 60# injectors, full 3" exhaust from zzp and that was it. remember i was on a budget. after honing and getting off a little slag that the bad piston left behind my cylinder wall was just a hair past the tolerence for the ring gap but **** i couldnt afford another set of pistons so i went with it. after the build my engine always burnt oil but my compression was good until i put 10,000 or so miles and then the compression started dropping slowly. what had me confused is that even with my good compression when i dyno tuned i was only producing 217whp when i was expecting more and should have had more. here recently i started spitting oil out my exhaust and my compression had started getting worse so now being a little older, make more money, and learned a little about building on a budget, i decided to tear the engine down again and start over. now, here comes my questions. I'm ordering the ported head with 78# valve springs, stage 1 cams, cooling mods, and pistons all from zzp. obviously my cylinder walls are worn past stock bore. i can get new pistons cheaper than buying and having new sleeves installed. what should i do? 88mm pistons will not work without machining the stock sleeves. i've read that you do not want to do that, but i was told that i could use an LE5 block. will all my other components match up with the LE5 block? or could i get by with something on the block that i have now? Still with buying a LE5 block and new pistons, it comes out cheaper than sleeving my lsj block. I need help.
Old Feb 8, 2013 | 02:14 AM
EXsoccer1921's Avatar
mrbelvedere. send him a pm about sleeves.
Old Feb 8, 2013 | 05:54 AM
DaFlyinSkwirl's Avatar
LE5 is gen II block, so it'll be a bit stronger.
LE5 bottom end (all stock) will bump up your compression.
if you install lower compression pistons and be ready to go.
the real question is: where do you want your powerband?
the short-stroke of the LSJ gives you a higher rod ratio. a higher rod ratio breathes better in the top end, so it'll pull longer. piston dwell at TDC is a bit longer, so you can run less ignition advance. higher rod ratio means less side-loading, so in theory, it will last longer as well.
the LE5 has a lower rod ratio. which means, it'll give a lot more torque and give it a lot earlier in the power band. however, top end breathing will always suffer, so power will taper off after the crossover point (5252rpm). headwork, cams, etc won't ever truly defeat this. an engine's ability to breathe is usually controlled by the rod ratio.
also, you have to use a clutch/flywheel combination for the LE5. the LSJ clutch/fly will not bolt up. (LE5 has 6 bolt fly, the LSJ/LNF has 8)
also, some LE5s don't have the external oil cooler like the LSJ does... but the LE5 does have the squirters inside.
please refer to post #8 in this thread:
https://www.cobaltss.net/forums/2-0l...builds-292623/
Old Feb 8, 2013 | 07:14 AM
this is great info. i really like my longer pull, so could i not just get a set of lsj pistons anywhere that are just a little oversized to keep from re-sleeving or finding an le5 block? the le5 block swap just has me a little nervous and afraid ill bite off more than i can chew. im still new to this.
Old Feb 8, 2013 | 07:18 AM
Vander Nars's Avatar
Get some sleeves from mr. B im not sure what he is charging but i think its around 500 for all 4 of them.
Old Feb 8, 2013 | 07:27 AM
yeah i'm thinking thats going to be my best option now. especially since i already have the diamond pistons. why bother with the headache
Old Feb 8, 2013 | 07:35 AM
Tjolley's Avatar
let me add to this
u have to clock the reluctor wheel on the crank. And the le5 flywheel will not fit inside the f35 trans.
some le5s did have oil coolers.
pm Mrb for some info on sleeves. Good luck with ur build
Old Feb 8, 2013 | 09:52 AM
mrbelvedere's Avatar
your cylinder pressure was dropping from excessive wear and being out of round and from more then likely using the grit on the hone my question Is what do the pistons look like post up some pics
Old Feb 8, 2013 | 10:43 AM
mr b. im out of town for work. when i get back home ill send pics. keep in touch, ill be needing your help
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
brandon04
Oct 21, 2015 07:04 AM
