lsj crank getting modified
Old Feb 13, 2013 | 10:14 PM
mrbelvedere's Avatar
the key will extend to #1 main bearing so the harmonic balancer has 2in of key to grab instead of a .25in and water pump gear is fully captured (it also only has .25 of the key running it)by the new key way also
as many of these engines as I have been into the crank key is always or close to being sheared off if you shear the dampner side you loose the oil pump as the dampner turns the oil pump if you shear the other end you loose the water pump so this should fix a potential problem
Old Feb 13, 2013 | 10:16 PM
TStone's Avatar
Shoulda used the search button
Jokin. Looks mighty fine mrb
Old Feb 13, 2013 | 10:18 PM
RedSSbalt246's Avatar
Very nice
Old Feb 13, 2013 | 10:24 PM
OneCOLDBIZL272's Avatar
Looking good John
Old Feb 13, 2013 | 10:59 PM
Tjolley's Avatar
Can't wait to do mine.
Old Feb 26, 2013 | 10:45 AM
key installed and rebalanced crank
Old Feb 26, 2013 | 11:04 AM
Staged07SS's Avatar
Administrator
Administrator
Nice stuff John!
Old Feb 26, 2013 | 11:15 AM
07ssBOOST's Avatar
I covered this ina thread already.. lol nice work man you seem very knowledgeable
Old Feb 26, 2013 | 12:28 PM
link your thread but this has been known for years
Old Feb 26, 2013 | 12:30 PM
07ssBOOST's Avatar
I was just playin around lol read it and thought it was interestin, good stuff!
Old Feb 26, 2013 | 02:29 PM
word up foshizzle
Old Feb 26, 2013 | 02:40 PM
zrated89's Avatar
weaksuace. Dont need no stinkin woodruff keys anyways!! free spinning balancer and free baller in da jeans fo da win
Old Feb 17, 2014 | 02:16 PM
Thank you!
Old Mar 1, 2014 | 01:27 AM
danielhubbard2001's Avatar
Beautiful!!
Old Mar 1, 2014 | 05:03 PM
SSfamilywagon's Avatar
I'll be doing this when I build my bottom end as I've personally had two friends cars break the stock keyway
Old Mar 1, 2014 | 06:08 PM
and people think im crazy
Old Mar 1, 2014 | 06:23 PM
TStone's Avatar
Oh you are crazy
Old Nov 13, 2019 | 03:54 AM
Miroed's Avatar
Will try to give life into this old thread. Does anybody know the details of this modification?
I believe that the key way groove should be extended all the way from the beginning of the crankshaft until the 1st main bearing surface? In this case what do you use as a key way itself? Any piece of material which is machined to the correct size?
Is it necessary to balance the crankshaft after it? Should is be balanced with new key way or without it?
Whatsoever details will be highly appreciated!
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Stuff
Oct 1, 2015 05:47 PM
cw383
Sep 30, 2015 12:41 AM
