LSJ/LNF/LE5 valve springs all the same?
Couldn't find any different part number for the valve springs, was wondering if there was any difference in height or seat pressure for any of the ecotec valve springs? I noticed ZZP only lists LNF valve springs as an OEM replacement but no part #. Was curious if its the same spring across the board.
so i imagine the cheapest spring upgrade is the zzp #82 spring kit? Do you know if these are specially made or they just getting them from another car with a higher spring pressure that somehow fits these motors? I've been trying to find a cheaper alternative, if I can find an OEM spring that matches it wouldnt cost much more then 5 bucks a spring lol
I'm probably going to be getting a set of mild regrinds made for my 2.4 SC swap, and I was looking to see if the LNF's were a little heavier then the LE5 or LSJ springs but it seems theres no difference. I would hate to over spring the valvetrain, ive never had good results running heavy springs when the cam didnt require it.
Yes. They are all the same.
Rocker design changed in late 07' though. Luckily my car came with the new design.
58#
Yup. I'd go with the supertechs.
I've been running the 75# kit in my car for over year now with many 7500 rpm blasts.
I am about to buy fuel cam and some springs but am kind of afraid of supertechs after hearing about grinding the head
installing with head on car..
edit:
https://www.cobaltss.net/forums/show...4230&styleid=9
never mind finally found some good info
