lsj turbo swap from lnf
I seached the forums but could not find my answer.
I have a friend that is going to sell me his turbo setup from his LNF.
It includes all piping, cooler, intake and turbo manifold. He also said he will include oil lines.
I know I will have to do some modifications but will this swap fit? I read something about the intake manifold not fitting due to a cooling line. All advice is welcome.
Where can I get a decent turbo for a good price?
ok its the exhaust manifold that wont fit because of the rear coolant pipe, you need both the rear coolant pipe and the thermostat housing from the LNF , also the oil return wont work on the lsj you will need a diferant return setup as for the intake manifold the bolt patern is diferant and the intake runner ports wont alighn right so your beter off geting aN intake manifold for the LSJ with that being said the cold side charge pipe will need to be diferant
read my how to on installing a k04 on non LNF engines, there is also a parts list in there to along with part numbers
https://www.cobaltss.net/forums/how-...nstall-287173/
with that said, the k04 isnt the best turbo for an LSJ. but its a good turbo for 300-330 hp.
jcalvin1126
09-11-2015 10:24 AM
Josh@ottp
09-08-2015 10:18 AM
