Lsj/tvs engine build #2
Old Sep 27, 2013 | 10:12 AM
  #176
Bluelightning's Avatar
Got Bewst?
Happen to know bolt size?
Old Sep 27, 2013 | 10:53 AM
  #177
mrbelvedere's Avatar
there are threaded holes to pull on no need to seperate iirc.
if the engine is in the car you cant pull it out as a complete assembly it will hit the frame rail so yes you need to separate
if you buy the puller kit they should be in it
Old Sep 27, 2013 | 11:15 AM
  #178
Got Bewst?
If you pull the bolt out of the front trans mount and take the 3 motor mount bolts out the engine will drop enough to get it out as a whole.
Ugh I really need to buy their kit to pull this thing off? I can't use a standard puller and buy some bolts?
Old Sep 27, 2013 | 02:40 PM
  #179
you can use a standard puller and **** dropping it out of the mounts
Old Sep 27, 2013 | 08:56 PM
  #180
Powell Race Parts's Avatar
this forum is funny. I did timing chain etc on an ATI equipped Cobalt with engine in the car, noone told me I couldnt do it, and it came off fine. I hardly needed the puller. I did drop the top mount.
some days I find the advice here weird. that is all.
as you were!
Old Sep 27, 2013 | 09:39 PM
  #181
Got Bewst?
I was able to put it in as a complete assy so i'm sure I can take it out as one
Old Sep 27, 2013 | 11:08 PM
  #182
you cant get your fingers between the frame and the dampener on my car if you just slit the dampener off then someone has had it opened up to slip fit
Old Sep 28, 2013 | 01:26 AM
  #183
Tjolley's Avatar
^^^ yup..
Think they were made with a 0.001 press fit
Old Sep 28, 2013 | 06:52 AM
  #184
? weird; the motor drops enough to clear. fyi just like bluelightening from windypeg says
Old Sep 28, 2013 | 08:28 AM
  #185
Tjolley's Avatar
Block and head r all ready to go.
Gona drop most of everything off at steves while Im at Disney land.
Still have a few minor things to finish cleaning.
Was hoping to take everything but Im Gona end up at work Proly close to 40 hrs between today and tomarrow.
Old Sep 28, 2013 | 08:58 AM
  #186
JapEatr's Avatar
South Central *********
Turned out great
Old Sep 28, 2013 | 09:03 AM
  #187
Tjolley's Avatar
Just wait till the next one. Lol
Old Sep 28, 2013 | 09:07 AM
  #188
Tjolley's Avatar
Im hoping Steve will give me the block that was blown up.
I have a experiment i Wana try to see it its even possible.
Old Sep 28, 2013 | 09:09 AM
  #189
574's Avatar
574
This car needs to run naow, excited to see what TVS+N20 will do
Old Sep 28, 2013 | 09:16 AM
  #190
Tjolley's Avatar
My car will be a Tvs+n2o+e85 in the next 2 weeks
Old Sep 28, 2013 | 09:18 AM
  #191
574's Avatar
574
Originally Posted by Tjolley
My car will be a Tvs+n2o+e85+2.4? in the next 2 weeks
eh?
Old Sep 28, 2013 | 09:22 AM
  #192
Tjolley's Avatar
Originally Posted by 574
eh?
Proly by the end of October.
The plan is to Get Steve's in and dialed.
Then ill get my 2.4 in. I have everything. Just need time to finish the head.
Between working like a slave at work and Steve's engine and my girl. I have no spare time.
Old Sep 28, 2013 | 12:55 PM
  #193
go look in the dyno section its been done
Old Sep 28, 2013 | 02:51 PM
  #194
574's Avatar
574
Last I saw it was only once streetdreamz, and iirc it doesn't say what size shot
Old Sep 28, 2013 | 03:31 PM
  #195
shot dose not matter you see the results from shitty tuning
hacadacalopolis
Oct 28, 2015 06:09 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
