lysholm build from hell pt 1.5
Old Jul 16, 2012 | 12:37 PM
BoomInIt's Avatar
Didn't have those codes with mine. Did have problems until I ported the head. Stock ported TB helps. Most issues I dealt with were with heat. You can tune without the maf for less issues. Once you got it tuned on gas definitely switch to e85 or e100 for cooling purposes. I have been running my 1.2L for years now. Try swithching back to the m-62 to fix the codes then back to the TS.
Old Jul 16, 2012 | 09:51 PM
jittjoey's Avatar
Originally Posted by 06_SIC_SS
no just thought u had an LS4.
was gonna but heard its a pain to tune with
Old Jul 17, 2012 | 06:32 AM
06_SIC_SS's Avatar
cobalt has the shittiest computer ever, its all a pain at first
Old Jul 31, 2012 | 12:34 PM
jittjoey's Avatar
good news is im getting a completely free hhr that was wrecked in the front from my drunk manager... so that should be a good chunk of change to part out... so it looks like the head work is going to practically free plus some
Old Jul 31, 2012 | 05:05 PM
chood711's Avatar
getting any closer to getting that thing done..
Old Aug 1, 2012 | 08:23 PM
jittjoey's Avatar
haha for the most part its done... i gotta finish up this custom bolt for the oil pressure gauge then its cake on the gasket maker to stop the idel from being off.... i think thats what i did wrong the second time i put all the parts from the intake to the supercharger... i only used gasket maker on one side of the cardboard gasket and the first time i had it on both
Old Nov 15, 2012 | 09:22 AM
mrbelvedere's Avatar
any updates
Old Jun 14, 2013 | 12:56 AM
jittjoey's Avatar
Old Jun 14, 2013 | 12:58 AM
Tell us about it!! Looks awesome
Old Jun 14, 2013 | 01:00 AM
jittjoey's Avatar
update running ready to tune as soon as i get new seals in the coolant transfer pipe which is leaking like hell and shifter cable clamp that needs replaced so i can have this bitch tuned enough to drive to supernats at least
Old Jun 14, 2013 | 01:01 AM
  #36
jittjoey's Avatar
doesn't sound bad either.... for sure whines at idle like i was told it would
Old Jun 14, 2013 | 01:02 AM
  #37
Bluelightning's Avatar
Got Bewst?
Put that back PVC clamp back on
Old Jun 14, 2013 | 01:07 AM
  #38
Cant wait to see a beastly vid of this car. Glad its.. Running? Lol.
Old Jun 14, 2013 | 01:23 AM
  #39
jittjoey's Avatar
i almost did miss it.... noticed it when my brother did a quick 5 min touch up on the pics... thanks for th eheads up thp
Old Jun 14, 2013 | 01:26 AM
  #40
jittjoey's Avatar
its running fine.... just cant shift it or keep coolant/water in it
Old Jun 14, 2013 | 02:31 AM
  #41
100% METH's Avatar
This is good
Old Jun 15, 2013 | 11:02 AM
  #42
jittjoey's Avatar
Someone help me get the damn coolant pipe out
Old Jun 15, 2013 | 11:48 AM
  #43
its a pain but it pulls straight
Old Jun 15, 2013 | 11:57 AM
  #44
Tjolley's Avatar
I think its easy..start swisting it back and forth.
If u use a lil high temp grease on the new O ring it will prevent it from happening next time.
Old Jun 15, 2013 | 12:45 PM
  #45
jittjoey's Avatar
Lol there is no chance in hell it's a straight pull I got the water pump side 95% out I can fit a finger in that end but it won't budge
It didn't ever really seal itself up with the o ring I think it was turned the wrong way causing it to leak but I have the seals so might as well replace them
Old Jun 15, 2013 | 12:50 PM
  #46
Tjolley's Avatar
Hmm wonder y its so hard.
I never ever had a issue with mine. Hmm
Old Jun 15, 2013 | 07:15 PM
  #47
jittjoey's Avatar
Got it out finally ... Seals are perfect and intact
Old Jun 15, 2013 | 07:20 PM
  #48
Tjolley's Avatar
Water pump bad??
Old Jun 15, 2013 | 07:42 PM
  #49
jittjoey's Avatar
No it's leaking from the other side for no goddamn reason ... Buying a new one off mongo and have new seals
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
