M62 boost question??
Old May 14, 2012 | 07:47 PM
briank6102's Avatar
How much boost can a ss/sc make with a 2.8 pulley and 50# Siemens injectors with cooling mods??
Old May 14, 2012 | 07:50 PM
05Slowline's Avatar
there are way too many variables
the norm would prob be 15-16lbs normal weather not cold not hot
Old May 14, 2012 | 07:51 PM
Sunburst_SS's Avatar
you should see around 17 psi
Whitnith's Avatar
Boost isn't a measure of horsepower. You can make all kinds of boost, but it isn't going to do anything by being so restrictive.
I was making 17 at one point, while on stock exhaust, and I got rid of that real quick.
I know make around 14, and have more horsepower than ever.
Old May 14, 2012 | 07:56 PM
05Slowline's Avatar
yea i aint feel like typing that when it's been typed so many times i tried to condense
Old May 14, 2012 | 08:00 PM
jonathan923's Avatar
i see 15-16psi on that POS 2.8 pulley, 80s, tuned and **** still slow as fawk....so depressing..
Old May 14, 2012 | 08:01 PM
05Slowline's Avatar
Old May 14, 2012 | 08:19 PM
briank6102's Avatar
I know boost does not equal hp.. Reason I'm asking is I'm getting ready to stage my ss and turbo Tim says anything over 16 psi does no good.. He said anything over that is just blowing hot air into the engine and it hurts more than helps.. So I was trying to get as close to 16 psi as possible.. I know that putting boost in doesn't help without letting it get out as quick as it gets in so I was gonna do header/dp and possibly a catback and then hptune plus meth injection
Old May 14, 2012 | 08:23 PM
briank6102's Avatar
What is the purpose of running 80's while still having a m62?? They say you can't max 50# injectors with the m62 right?? Are you planning for more mods for the future or what? And did you at least notice a difference or did you expect more out of the kit?
Old May 14, 2012 | 08:24 PM
Whitnith's Avatar
Originally Posted by briank6102
what is the purpose of running 80's while still having a m62?? They say you can't max 50# injectors with the m62 right?? Are you planning for more mods for the future or what?
e85
Old May 14, 2012 | 08:25 PM
05Slowline's Avatar
he had to sell his turbo kit lol.
idk why tim is saying by psi that's odd he prob meant certain pulley size....2.8 is prob the lowest i'd do without meth inj or e85
Old May 14, 2012 | 11:10 PM
ebristol's Avatar
That is what "They" say but I would like to see proof.
Old May 15, 2012 | 08:06 AM
briank6102's Avatar
Ooh.. That's shitty.. I can see why he's mad now.. Tim was talking about pulleys. He said 2.8 should have cams and header/dp plus dual pass and the whole goal is to get as close to 16# without going over..
Old May 15, 2012 | 08:08 AM
briank6102's Avatar
Originally Posted by Whitnith
e85
What are the gains with e85? Good? And where can you get it
Old May 15, 2012 | 08:44 AM
hhrfreek's Avatar
Thats right...I just took my 2.7" off and put on a 2.9" because it made too much heat and could not do back to back pulls. It was nice this spring when it was cooler but now it sucks. Cruising temps are 20 degrees above ambient with the 2.9" and the 2.7" is 30 degrees. Also by the end of a 3rd gear pull with the 2.7 iat2 was ~25 degrees higher than the 2.9" and the temps never recover as fast either.
Look at the dyno list...almost all of the higher numbers for lsj have used e85. Check around local gas stations for e85.
Old May 15, 2012 | 09:09 AM
sujomatt's Avatar
Not to Thread jack, but I am at 15PSI with a 3.0pulley and GM tune/injecotrs. Full exhaust and 3" intake... does that seem right? Or should I be at a lower level? I have a ebay exhaust (from what I can tell). Will be dropping to a 2.8pulley - don't want to be at like 20PSI lol
Old May 15, 2012 | 09:11 AM
Staged07SS's Avatar
Administrator
Administrator
No one can really say exactly what your boost should be, because there are so many factors that can alter it. Things like: temp, elevation, modifications, etc.
15 psi is average for the GMS2 setup.
Old May 15, 2012 | 09:22 AM
Originally Posted by staged07ss
no one can really say exactly what your boost should be, because there are so many factors that can alter it. Things like: Temp, elevation, modifications, etc.
15 psi is average for the gms2 setup.
this.
Old May 15, 2012 | 01:11 PM
574's Avatar
574
This right here is why I haven't pullyed down yet. I don't think the gains are that noticable unless you go turbo or TVS
Old May 15, 2012 | 01:22 PM
nwss's Avatar
if you arent using a mechanical boost gauge more then likely you will be a few psi off, i was hitting 17 on my 2.9 with the stock gauge now im at like 15-16 with the mechanical.
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
Extremespeed
Sep 29, 2015 04:34 AM
goaliemo
Sep 28, 2015 01:37 PM
Iceberg
Sep 28, 2015 01:31 PM
