m62 psi / pulley
Old Dec 16, 2009 | 12:32 PM
joe_589's Avatar
m62 psi / pulley
hi, does anyone have a chart for the boost the m62 should be running on different pulleys
i have searched but cant seem to find it! i imagine it is because you lot have boost gauges fitted
unfortunately i dont
Old Dec 16, 2009 | 12:36 PM
SCcobaltSS's Avatar
it'll be different with size of exhaust. Why do you want to know? Boost doesnt = power necessarily.
Old Dec 16, 2009 | 12:38 PM
joe_589's Avatar
just out of curiosity
here is a graph for the harrop Pulleys
64mm - 27.5psi
70mm - 25psi
75mm - 22.5psi
80mm - 20psi
85mm - 17.5psi
89mm - 15psi
Old Dec 16, 2009 | 12:41 PM
WickedSS2005's Avatar
On average w/ stock exhaust parts and stock head, results will vary on porting, header, exhaust size
3.35" = 12.5 (stock)
3.0" = 15 (GM stage2)
2.9" = 16
2.8" = 17
2.7" = 18
2.6" = 19
2.5" = 20
This is all relative. Elevation, ported blower, and above mentioned exhaust work/ported head will decrease pressure by increasing flow. Which is good. My ported 2.6" m62 w/ full 3" exhaust ran 16psi
Old Dec 16, 2009 | 12:43 PM
Tomtwtwtw's Avatar
Boost is completely dependent on how well the rest of your engine flows. There is no definitive chart on xxx pulley size = xxx boost. Even that Harrop one is only an approximation.
Old Dec 16, 2009 | 12:47 PM
joe_589's Avatar
thanks alot for that, i think i need to get hold of a gauge.
does anyone know where to get one and how to fit it?
my current setup is low compression overbore 2.2 with ported head, 3" full exhaust system, 2.8 pulley soon to be 2.7 and soon to have some blower cams
many thanks
Joe
Old Dec 16, 2009 | 12:52 PM
selfinfliction's Avatar
+4006 psi for each 0.10" dropped
Old Dec 16, 2009 | 12:53 PM
SCcobaltSS's Avatar
^you and that damn number
Old Dec 16, 2009 | 12:59 PM
joe_589's Avatar
i eem to remember reading a thread with you posting that number the othr day
Couldn't guess what psi you'll see. That rough chart i did was for the LSJ (2.0) no the L61 2.2L The 2.2 will see lower psi, and ported this, changed that will all effect the pressure
Old Dec 16, 2009 | 01:03 PM
joe_589's Avatar
anyone got a spare guage that they dont mind sending to the uk?!
also how do you wire it in? into the map sensor? or do you hve to run it through the ecu
Old Dec 16, 2009 | 01:17 PM
4006 is now my answer to everything here.
"what's the top speed of an ss/sc? " 4006 mph
"how much power will XXX and XXX mods give me?" 4006whp
"my car blew the sleeve during a race" that's because you were trying to make 4007whp when clearly the engine will only support 4006whp
it's all common knowledge
Old Dec 16, 2009 | 01:22 PM
If you have a 2.2, then the gauge will simply tie into a vac line
Old Dec 16, 2009 | 01:31 PM
joe_589's Avatar
sorry what do you mean by vac line?
thanks
joe
Old Dec 16, 2009 | 01:47 PM
SCcobaltSS's Avatar
That is why I said my comment. I think I have seen it in a few threads
thanks
joe
vac "vacuum" line off of the intake manifold.
Last edited by SCcobaltSS; Dec 16, 2009 at 01:47 PM. Reason: Automerged Doublepost
Old Dec 16, 2009 | 01:48 PM
joe_589's Avatar
do i have to take it off the inlet manifold... hmm how do you do this drill a hole and fit a sensor?
thanks
Old Dec 16, 2009 | 01:57 PM
SCcobaltSS's Avatar
thanks
drill... I dont believe you have to. Get a mechanical boost gauge, do you have the LSJ intake manifold? If so there should be a Vacuum line nipple that is just under the fuel rail (unless the fuel rail is located in a different location vs. LSJ). Tee into that (again unless the 2.2 do it a different way) and run it to the gauge.
Old Dec 16, 2009 | 02:12 PM
joe_589's Avatar
Ahh yes Im pretty sure where you mean, u do have to use a lsj inlet manifold, will buy a T piece and go into that.
Will update with a list of my mods and the psi Reading once I have it
Old Dec 18, 2021 | 01:22 PM
Smc252's Avatar
2.9" = 16
2.8" = 17
2.7" = 18
2.6" = 19
2.5" = 20
I also have a full 3" with long-tube header, 2.8" making 14psi, did a maf retune, added 5-10% fuel, it pulls pretty hard. I am impressed. Stage 2 injectors run at 104% DC at 6800rpm, at 10.78afr. Next mod is obviously injectors and a zzp pulley tensioner bracket.
Old Jan 21, 2023 | 05:55 AM
annamartino's Avatar
sheape
Forced Induction
Feb 17, 2014 11:09 AM
J0HNNYG85
Mar 28, 2011 09:40 PM
phxSS
Aug 1, 2008 10:48 AM
Jmc007
Forced Induction
Apr 30, 2006 01:49 PM
