MAF P101 problems
MAF P101 problems
Long story short.. i have the TVS now with the 2.6 and 80 lb siemens..
put the OTT 3 inch intake on and started throwing MAF P101 codes.. and the car would run rediculously rich at PE.. pins at 10.0 on the wideband
thought the MAF sensor was shot so i put in a new one.. 4 or 5 hours later.. same code.. shitty throttle response, bucking under acceleration, sputtering.. runnin like hell for the most part
changed air filters to a dry flow and i have the same problem, finally revert to putting my K&n CAI back on with the new sensor, car runs fanastic, mid 11s on the AFR under WOT, runnin strong... thought i had the problem fixed, cruising home in 5th, p101 flashes on, and the car goes back to being at 10.0 under throttle..
what am i missing here? i am at a total loss for what i need to do????
is this something that needs to be worked out with tuning? and im totally lost on why swithcing back to my 2.5 intake solved the problem 100% for the entire day until now
not that i have been able to find.. and it doesnt make sense to me that the 2.5 inch intake made the car run beautifully for an entire day..
bump...any insight on this?
It could be a vacuum leak. If you don't find a vacuum leak, and the car runs great all the time before the code sets, I would just delete the 101 code out of the ECM file. Otherwise, you need to have the MAF chart adjusted.
i definitely think this is what i need done.. ive checked all my lines and around the bung.. ima get some tuning in sunday.. i will post up how it goes.. i got some real good advice on what to change in the tune so ima give that a shot
