Major coolant issues
Old Dec 19, 2007 | 01:36 PM
n323er's Avatar
Well last night was getting on the gas a little heavy while racing stock evo 8 from 40mph roll. Right at the top of 2 gear clear white smake everywhere Looks like the upper radiator house ripped off guess while under pressure. Anyways car at the dealership right now while in there will get the tranny fixed as 2nd gear is out. Service writter stated that it was 6 hours labor to replace tranny thought it was 10 by the book of course I am not going to disagree but I am sure I will recieve a phone call today stating "hey it is going to be more". Anyone had this coolant problem with the cobalt
Cheers
RYAN
Old Dec 19, 2007 | 01:42 PM
07 SS/SC's Avatar
Soooo you were racing your car while 2nd gear was out??
Old Dec 19, 2007 | 01:43 PM
bgbearcatfan's Avatar
someone knows how to treat their car right
D4u2s0t's Avatar
yea, a 40 roll in third bro. that's the sweet spot. you have the advantage because you don't have to shift for like 10 seconds
Old Dec 19, 2007 | 02:03 PM
n323er's Avatar
used the old double clutch method and i am sorry i do not treat my car to your stanards
Old Dec 19, 2007 | 02:05 PM
D4u2s0t's Avatar
why are you double clutching a car with synchros?
**edit. partial deletion. made post nicer **
Old Dec 19, 2007 | 02:09 PM
Super_SS's Avatar
2nd gear is 40mph sweet spot for the balts,especially if u have s2
Old Dec 19, 2007 | 02:11 PM
D4u2s0t's Avatar
yea, i was obviously joking about 3rd at 40 being the "sweet spot". i probably should have put a smiley or something
Old Dec 19, 2007 | 02:12 PM
^^ lol sure you were joking..... jk
Super_SS's Avatar
hey i figured there are some noobs on here that arent really sure..remember that guy that raced the mazdaspeed 3...40mph 3rd gear and got walked
n323er's Avatar
ok guess i should br more spacific 2nd gear synco out that is why tranny is being replaced therefore a double clutch will get it into to second or rev match and yes 2nd gear is sweet spot for ss bolt 3 rd would be no go at 40 mph way below the pwr band with stg III or for that matter a stock one as well
RYAN
Old Dec 19, 2007 | 02:15 PM
Super_SS's Avatar
RYAN
im sorry man,but i have no clue on wat u just said,might be me,but no sure
D4u2s0t's Avatar
yea. i shift into 3rd at about 70. no way i would try to race from 40 in third
Old Dec 19, 2007 | 02:19 PM
RaineMan's Avatar
why am I reminded of that quote from fast and the furious??
Mmm... granny shifting... not double clutching like you should... yadda yadda yadda...
Must be that Stage XVIII super dooper boost-a-rific mod overpressurizing your blinker fluid system.
Old Dec 19, 2007 | 02:47 PM
n323er's Avatar
that is what I am trying to say you are a mind reader cheers
Old Dec 19, 2007 | 03:23 PM
2K5SS/SC?'s Avatar
First off you most likely blew the headgasket, and if you're lucky the engine might be salvagable. If not, you probably blew the engine in a bad way.
Secondly 3rd gear at 40mph is not our sweet spot! 2nd gear at 40mph is good and 2nd gear at 50mph is our MONEY SHOT!
Old Dec 19, 2007 | 03:51 PM
D4u2s0t's Avatar
reading > you. i said it was a joke, and i thought it obviosly was. though i still should have put a smiley there.
Old Dec 19, 2007 | 05:20 PM
Area47's Avatar
Rent me! per hour
i prefer 2nd at 30mph.
torque is fun.
Old Dec 21, 2007 | 01:05 PM
n323er's Avatar
Not sure how smoking from radiator would be head gasket ????
Old Dec 21, 2007 | 01:17 PM
LopsidedJester's Avatar
Are you asking a question whether the trans work should take that long? With just taking off the trans 5 hours is minimum charge from the dealer or $500 at least is what i've seen, but to actually fix something inside that will be a hell of a lot definitely over $1000 for synchro replacement i'm guessing here though, sorry man.
For the white smoke, if your hose fell off, that should take 2 seconds, but you might want them to tell you whats really wrong first.
Old Dec 23, 2007 | 01:14 PM
2K5SS/SC?'s Avatar
My bad, I missed the radiator hose part! However, if the hose was on tight in the first place and it blew off under full boost, you could have a headgasket that is blown. What happens is that under full boost it allows the head to lift or the gasket to displace resulting in boost pressure going into the coolant blowing off hoses or plastic radiator seals. This happened to my Integra when the headgasket blew at 15psi.
brandon04
Oct 21, 2015 07:04 AM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
riceburner
Sep 26, 2015 12:57 AM
