Making the LS4 TB driveable
Old Apr 16, 2009 | 12:47 PM
johnladow07's Avatar
I put the scalar at 4950 and havent had any issues with drivability. I have had it for about a month or so and can drive my car just as smooth as I could with the stock TB. I do have the boost limited in first, but not sure of the exact number's.
Old Apr 16, 2009 | 12:52 PM
HunterKiller89's Avatar
Originally Posted by Rodimus_Prime
i put down 16 more hp over my last dyno and it was the only thing added besides some tuning
here is your gain in power, and normally, yes, you can just change the ETC scalar and go. If there was any change to your timing, thats why you gained power. You're replacing a non-restrictive part with an even less non-restrictive part. There would not be a 16hp gain solely from that swap
Old Apr 16, 2009 | 05:52 PM
Rodimus_Prime's Avatar
i also have first gear boost limited
that alone did help but is not quite the full answer
Old Apr 16, 2009 | 11:13 PM
StevesBlack06's Avatar
Originally Posted by HunterKiller89
thats not really true, but the guy you're responding to is definitely confused, becasue the LS4 and the LSJ TB DO use the same wiring.
To explain to the confused guy, the area scalar tells the ECM when the throttle is open X%, what volume of air should be flowing through it. If it expects X CFMs at 10% throttle, but is seeing 1.5X CFMs at 10% (since the larger TB will flow more at the same throttle percentage), it can do many things, including at the extreme thinking there is a vacuum leak, and put you in limp mode.
If you tell the ECM the TB is bigger than it really is, it will open the throttle less per the same pedal travel since it is trying to get X CFMs at Y pedal travel.
I hope this made sense....And I hope what I said is accurate, but this is my understanding how it works.
hunterkiller89 thanks for clearin that up for us and me in general. i understand what your sayin.
Old Apr 16, 2009 | 11:31 PM
I loaded up the 5500 scaler today, a bit too early to tell if its helping but I really enjoy having the low end power back again
Im having intermittent issues with my hp tuners cable not working so its making things much harder, if anyone wants I can upload tonights log
Old Apr 17, 2009 | 07:36 AM
TRANSAM197781's Avatar
i wanna see keep me updated
Old Apr 17, 2009 | 08:30 AM
Darkmanx's Avatar
how bout you take off the tb and go back to the dyno and see if you make any less power.
Old Apr 17, 2009 | 08:31 AM
QuikSilverSS's Avatar
I found my car made better power with the stock Tb over the LS4 one, you would get all kinds of throttle response with the LS4, but the mid range and top end seemed better with the stocker. Not sure what every one elses experience was
Old Apr 17, 2009 | 10:37 AM
I seem to also experience lower IATs with the LS4 on as well
Old Apr 18, 2009 | 02:01 AM
SSLOW06's Avatar
I Just Installed An Ls4 And I Should E Getting Tuned Correctly Some Time Next Week But Yes The Car Is Very Sensetive Now ! Its Crazy Makes Me Look Like I Never Drove Stick Before ! Lol I Just Ease Off The Gas And Throw It Into 2nd So I Dont Look Like A Fool Driving In Traffic
Old Apr 18, 2009 | 10:35 AM
  #36
it seems to be for the most part ok, im still working out the MAF table but theres not much issue now
Old Apr 21, 2009 | 10:24 PM
  #37
ArielAtom's Avatar
So did the 5500 scalar make the difference? or was there another measure taken in there? I am wondering if my car is too light to ever make it work well enough.
Old Apr 21, 2009 | 11:07 PM
  #38
Ryze's Avatar
Personally, my Ls4 was a night and day difference..
Ran a friends car (lsvtec CRX) from a 40roll without it, and he pulled a good half length on me, after i swapped to the ls4 tb, i would stay atleast 1/2 length in front of him..
yes its not scientific and its not the smartest thing in the world to do, but that is MY experience with. believe it or not, I think it works.
Driveability...eh its a little harder, just keeps me off the gas pedal as much.
what cable problems are you have RP?
Old Apr 22, 2009 | 12:15 AM
  #39
HondaHater's Avatar
I just put my LS4 on a couple days ago....that first gear is tricky at first. but the response is awesome!! i know i 100% gained power on it. i also got tuned too...but my car NEVER has been so responsive since i've owned it.
my g/f....whom never notices ANYTHING new i do to my car.....got in and said "you're car seems like it doesn't hesitate anymore and runs smoother now". So if she notices....there is a def difference.
my a/f or timing or anything like that wasn't changed in my tune. the LS4 leans you out a bit because of it delivering more air faster.
the things that were changed in my tune were:
PE @ 2500 rpm
7200rpm redline
LS4 scaler
speed limiter delete
50% boost in 1st
Old Apr 22, 2009 | 02:02 AM
  #40
Area47's Avatar
Rent me! per hour
some of you need to learn how physics work before you go making huge claims.
Old Apr 22, 2009 | 06:59 AM
  #41
scott allen's Avatar
Whats your thoughts on the ls4 tb? Look at my sig did i do the right thing? thanks
Old Apr 22, 2009 | 10:31 AM
  #42
Well intermittently now my hp tuners claims that the key needs to be to the on position when i try to scan or write a calibration, after unhooking the cable from the box 20 times then it starts working again, I dont get it never in the 3.5 years ive had it did it ever do this.
The things that I did to smooth it out was of course tuning the MAF table, set the scaler to 5500 and then cutting off boost in 1st completely to 4250 then ramp it in very slow
Old Apr 22, 2009 | 10:54 AM
  #43
ArielAtom's Avatar
Thanks RP! We are looking down the same path right now. At this point boost has not been cut as radically as you have. Every car and engine is a little different, but, that gives me a clue as to where to be.
Old Apr 22, 2009 | 11:11 AM
  #44
the boost cut made the biggest difference and even that I dont think does it properly, reason being if you have ever noticed if say you run no boost in first gear at all then stomp on it in first or even at half throttle for that matter you will noticed that it jumps into boost then back out and then back in again and so forth. By nature jumping in and out of boost is going to cause some roughness in driveability.
I guess the factory bypass valve or whatnot is still allowing some boost to build I don't know anything about boost controllers but if theres a better way that boost can be properly cut but only in first gear that might help a tad also.
Old Apr 22, 2009 | 11:25 AM
  #45
ArielAtom's Avatar
That is certainly not an area of my expertise, but, what you said makes sense from the standpoint of they would have had no reason to design that out of it. We will see, I am trying shortly.
Old Apr 22, 2009 | 11:28 AM
  #46
ShortStack's Avatar
Very good point....
Old Apr 22, 2009 | 02:07 PM
  #47
Area47's Avatar
Rent me! per hour
i put one on. physics slapped me silly. i pulled it off. with a stock head, you don't need it.
Old Apr 22, 2009 | 02:09 PM
  #48
im going to try the ls4 but if it gives me any **** ill go back to the lsj one.Did you lose power when you went back with the lsj?
Old Apr 22, 2009 | 02:19 PM
  #49
Area47's Avatar
Rent me! per hour
newp. runner reversion is a bitch
Old Apr 22, 2009 | 05:53 PM
  #50
whatever happened to anyone making a new intake manifold for us?
or did rebel rape ppl out of money on that too?
