MAP sensor and lead???
Where exactly is the MAP sensor on our engines (2.0 LSJ) ? Also what wire is the MAP lead wire? I'm trying to wire up my DevilsOwn meth injection and need to splice the progressive controller into MAP lead.... Help please
The Map is located on top of the manifold to the left of the supercharger housing (near the serpentine belt)if you're looking at the front of the engine. It should have four wires to it... dark green/white, light blue, dark green, and gray. You want the gray one for a signal.
We actually have all 3 sensors, plus an additional MAP located before the supercharger but after the throttle plate. The car uses MAF exclusively for fueling but calculates projected models of incoming air based off the two MAPs and TPS to make sure the MAF and electronic throttle are operating correctly. When these models don't match up, thats what causes limp mode. Little FYI.
which should i use for the devils own controller? i located the map you spoke about and used my multimeter, both the green and the gray show slight voltage with the ignition off and about .5v when the switch is on. Im terrible with wiring
That was the grey one right? As it looks front the picture above.
Oh yeah, one more thing, where did you get at the wire to splice onto it?
Bump for more info!
Bump for more info!
Last edited by BlackSS/SC; May 11, 2007 at 01:53 PM. Reason: Automerged Doublepost
Sl0wbaltSS
Nov 21, 2018 11:11 PM
