MAP sensor and lead???
Old May 1, 2007 | 08:03 PM
607Motorsports's Avatar
Where exactly is the MAP sensor on our engines (2.0 LSJ) ? Also what wire is the MAP lead wire? I'm trying to wire up my DevilsOwn meth injection and need to splice the progressive controller into MAP lead.... Help please
Old May 1, 2007 | 08:12 PM
07cobaltowner's Avatar
its a MAF!
Old May 1, 2007 | 08:16 PM
Witt's Avatar
The Map is located on top of the manifold to the left of the supercharger housing (near the serpentine belt)if you're looking at the front of the engine. It should have four wires to it... dark green/white, light blue, dark green, and gray. You want the gray one for a signal.
Old May 1, 2007 | 08:17 PM
06blackg85ss's Avatar
there ya go man.
Old May 1, 2007 | 08:34 PM
thanks a ton!!!! i'll get it hooked up asap
Old May 1, 2007 | 08:49 PM
Witt's Avatar
No problem. That info is according to alldatapro. Im not near a car right now to verify that, but their info is correct 99% of the time.
Mikey851's Avatar
Originally Posted by 07cobaltowner
its a MAF!
He's talking about a MAP sensor, not a MAF sensor. MAF cars usually have a MAP sensor to read barometric pressure changes as well as act as a failsafe.
Old May 1, 2007 | 08:50 PM
oppsoros ic ddasied ahve rvun fun
gb
Old May 1, 2007 | 08:52 PM
Witt's Avatar
We actually have all 3 sensors, plus an additional MAP located before the supercharger but after the throttle plate. The car uses MAF exclusively for fueling but calculates projected models of incoming air based off the two MAPs and TPS to make sure the MAF and electronic throttle are operating correctly. When these models don't match up, thats what causes limp mode. Little FYI.
Old May 1, 2007 | 09:02 PM
which should i use for the devils own controller? i located the map you spoke about and used my multimeter, both the green and the gray show slight voltage with the ignition off and about .5v when the switch is on. Im terrible with wiring
Old May 1, 2007 | 09:04 PM
Mikey851's Avatar
Ahh I see. Thanks for the FYI.
Old May 1, 2007 | 09:10 PM
Witt's Avatar
I'm gonna go with gray. Heres a pic of the connector with the wires labeled.
Old May 1, 2007 | 09:15 PM
i'll give that one a try tomorrow and keep you updated, thanks again man, much appreciated.
Old May 11, 2007 | 10:21 AM
BlackSS/SC's Avatar
Which wire did you end up using? I have the same kit, how does it work?
Old May 11, 2007 | 11:07 AM
oops I forgot to update I used the # 4 MAP Sensor Signal as pictured in the above diagram and it works perfectly.
Old May 11, 2007 | 01:53 PM
BlackSS/SC's Avatar
That was the grey one right? As it looks front the picture above.
Oh yeah, one more thing, where did you get at the wire to splice onto it?
Bump for more info!
Last edited by BlackSS/SC; May 11, 2007 at 01:53 PM. Reason: Automerged Doublepost
Old Feb 16, 2008 | 06:51 PM
QuikSilverSS's Avatar
Bump for more info!
update on thjis please? is it the gray wire? I am in the middle of the install now
Old Feb 18, 2008 | 10:14 AM
Yes it was the gray wire, good luck man!
Old Feb 18, 2008 | 10:17 AM
yep got it thanks guys
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
