Massive oil consumption issue (pic inside)
Old Sep 6, 2010 | 04:50 PM
  #51
ebristol's Avatar
So. What the news?
Old Sep 6, 2010 | 10:07 PM
  #52
VeNoM0713's Avatar
Originally Posted by ebristol
So. What the news?
i dont know lol.. this car is pissing me off but besides that. im either going to replace the rings or just say f*ck it and throw a stock block in there and call it a day.. i dont have anymore money to throw into this thing and i definately cant afford for it to be down again if i tear it down, replace the rings and it still smokes like crazy. as far as the block is concerned, it could only either be the rings or maybe the sleeve wasnt pressed all the way in or something?
Old Sep 7, 2010 | 03:39 PM
  #53
USMCFieldMP's Avatar
Rattlesnake Race Shop
If the sleeve wasn't pressed in all the way, you'd have a whole slew of other problems.
Just replace the rings and you should be fine.
Old Sep 7, 2010 | 05:29 PM
  #54
VeNoM0713's Avatar
well either way, i just bought a set of new rings, we'll see what happens.. when the block gets torn down im going to take it to a local machine shop so they can look it over, make sure everything looks ok..
Old Sep 7, 2010 | 08:10 PM
  #55
selfinfliction's Avatar
make sure they install them the right way, those things only work one direction
Old Sep 7, 2010 | 11:04 PM
  #56
mrbelvedere's Avatar
the second ring is file to fit set the ring gap at 19 to 21 thou second ring only
Old Sep 8, 2010 | 12:18 PM
  #57
VeNoM0713's Avatar
hopefully it wont be that bad... i just hope its the rings and thats that.. im running out of patience (and money) only thing im concerned about is why it would be the rings even though i have consistant compression through all cylinders.. (160-165) im going to do another compression/leakdown test this weekend also..
Old Sep 8, 2010 | 01:01 PM
  #58
i did a test on mine right after i replaced the pistions and rings and i went 225lbs each cylnder total seal recomends a the hone grit of 240 to 280 for a finished cylnder and not to beat on it but not drive it like a ***** either it takes heat to help seat the rings and they also said do not use synthetic oil period untill the rings are seated they also recomend wd40 for assembly lube on the pistons and rings
Old Sep 8, 2010 | 01:18 PM
  #59
SuperchargedSS's Avatar
Something is not right here for you to want to walk away so quickly on this. You just invested lots of $$$ in getting it to this phase. I mean you just need to button down one last cyl and your done. Stay on it. Youve dropped 3gs on the engine, you can scrounge up the cash to have one cyl looked at. I don't mean to pile on here, but what were you thinking cruising around for 150 miles, blowing smoke like a ricer in limp dick mode?
Man..
Old Sep 8, 2010 | 03:38 PM
  #60
Zooomer's Avatar
Supporting Vendor
alright, update for everyone.. and i also need your guys input because at this point im at a deadend.. we switched out the head this past week.. its still burning massive oil so it has to be an issue with the block itself. its only on the 3rd cylinder and oil is still pooling on top of the piston.. i think im going to just throw in a stock shortblock and call it a day. i dont have anymore money to throw into this car.. anyone know where i can get a shortblock for a decent price?
3 grand for a built motor that's **** and the company won't stand behind it?
You shoulda had ZZP do it.
-Less money
-Proven performance
-A real warranty
Ryan's LSJ is currently running 610WHP with no issues. Pretty basic ZZP engine build
Our sister company Fusion has used LSJ engines for a grand or less depending on miles. Just checked, $950 for an assembled long block with 59k.
Old Sep 8, 2010 | 04:19 PM
  #61
VeNoM0713's Avatar
Man..
make that 375 miles running in limp dick mode lolz.. but seriously though, im not quitting already.. i finally got my limp mode CEL fixed! im so happy about that.. turns out it was what i thought it was in the beginning.. the stupid WOT box was acting up so i just took that off and all the wiring to go with it. thats one less problem i have to deal with but this smoking is horrible.. i dont know if i should try to beat on it a little bit because maybe i have a stubborn ring thats not seated properly or just say **** it and tear it down and check everything.
Old Sep 8, 2010 | 04:24 PM
  #62
VeNoM0713's Avatar
interesting.. is this information included in the ring kit? im going to do another compression test/leakdown test this week sometime. i think either way though, my motor is going to have to come back out : ( i should take an updated vid of the ridiculous oil im burning now that i got my limp mode CEL fixed.. this **** sucks lol
Old Sep 8, 2010 | 06:34 PM
  #63
damien's Avatar
Just gonna put this out there...
I went and ran my car immediately after the first start. Within 25 miles the car was seeing WOT up until 5500. I varied RPM's quite a bit and always downshifting and coasting in -20Hg vac. You need pressure to seat those rings nice and tight. 20k miles later it's throwing 200psi across all 4.
Old Sep 8, 2010 | 08:22 PM
  #64
FUSION's Avatar
Supporting Vendor
We have at least 5 to choose from.
Old Sep 9, 2010 | 03:10 AM
  #65
Any LNF bare blocks?
Probably not.
Old Sep 9, 2010 | 10:55 AM
  #66
FUSION's Avatar
Supporting Vendor
Probably not.
Sorry all we have is 2 complete LNF's
Old Sep 12, 2010 | 01:14 PM
  #67
VeNoM0713's Avatar
alright, another update.. did another compression/leak down test yesterday and i am now showing 210-215 across the board.. i now have 400 miles on her.. leakdown test was between 12-15% across.. but im still smoking like a bi*ch... possible the oil ring in #3 is junk??
Old Sep 13, 2010 | 12:04 AM
  #68
yup it is possable thats what ive been saying
ineedacobaltss
Nov 7, 2015 02:25 PM
Tupp
Sep 30, 2015 08:18 PM
grampss
Sep 27, 2015 08:51 PM
