Max Boost, Stock MAP?
Old Mar 23, 2012 | 05:34 PM
supajut's Avatar
Ugh, I have search and cannot find a clear answer to this simple question. Some say 14.7, but that is more than a stage 2 pushes... How much boost can stock MAP handle?
Old Mar 23, 2012 | 05:52 PM
Pyros777's Avatar
The stock LSJ TMAP hits 270.59 kpa at 5V. That is equal to about 24.74 psi. That is not to say the sensor will just give up at 5V. That is just as high as it can read.
The most the PCM will ever be able to process is 255 kpa or 22.48 psi, so the stock sensor is more than sufficient.
Old Mar 23, 2012 | 06:09 PM
supajut's Avatar
Thank you!
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Sep 27, 2015 08:53 PM
