meth and E85
Old Jul 11, 2010 | 03:30 PM
Jmoney's Avatar
meth and E85
can a good mix of meth equate to E85 in octane and bring out the same kind of timing as E85. i looked and couldn't find an answer.
Old Jul 11, 2010 | 03:33 PM
05Slowline's Avatar
Yes. I'd rather run e85 over meth though personally.
Old Jul 11, 2010 | 03:35 PM
conerboner's Avatar
I've been thinking about converting to e-85. I just don't know how practical it would be. How hard is it to convert?
Old Jul 11, 2010 | 03:36 PM
05Slowline's Avatar
just need bigger injectors and a tune.
the only shitty part about e85 is there are different blends for different seasons and you can't find it as well as you can regular fuel.
Old Jul 11, 2010 | 03:38 PM
conerboner's Avatar
I have both. I have ford 39 lbs/hr injectors that came with my zzp stage 2 turbo kit. Would I need even bigger injectors than that? I thought you had to change the fuel pump and fuel lines too?
Old Jul 11, 2010 | 03:40 PM
05Slowline's Avatar
lulz 39lbph is barley bigger (maybe the same?) size as stock lsj. most running e85 are using 80lbph injectors. no need to change anything else.
Old Jul 11, 2010 | 03:42 PM
conerboner's Avatar
What Vince told me was the ford 39's are like 50's on a GM but I could be wrong. I'm done thread jacking tho
Old Jul 11, 2010 | 03:45 PM
Jmoney's Avatar
what kind of mix would u say would get me to E85 octane level
Old Jul 11, 2010 | 03:53 PM
Bl4des's Avatar
i think e85 and meth have the same octane so you will never reach the octane of e85 buy spaying some meth
Old Jul 11, 2010 | 03:54 PM
05Slowline's Avatar
What? Pretty sure 39 means 39 no matter what brand. I could be wrong but I don't think so.
90/10 meth/water
Old Jul 11, 2010 | 04:05 PM
BennyHHR's Avatar
WOW, just WOW!!!
So much misinformation here!
You will NEVER flow enough meth to match E85!
The Ford Cobra 39's are rated at Ford's 39.15 PSI. With our GM's 58 PSI they flow 47.46 GPH.
Old Jul 11, 2010 | 04:10 PM
05Slowline's Avatar
Originally Posted by BennyHHR
WOW, just WOW!!!
lulz nice bolding skillz but no one ever said that enough meth could be flowed to match e85...
as for the injectors....yeah depends on what psi it's advertised at thats a different story. still prob wanna go larger for e85.
Old Jul 11, 2010 | 04:16 PM
rico's Avatar
agreed
Old Jul 11, 2010 | 06:04 PM
Redefined1's Avatar
i would rather run meth. e85 has an octane range of 94-96 (R+M)/2. These calculations have been confirmed by actual octane engine tests. I run a methanol rating of 120 once its mixed with my 94 octane. why would you say you cant run a higher octane with methanol? pulled those calculations off of wikkipedia.
Old Jul 11, 2010 | 06:30 PM
05Slowline's Avatar
I've bolded the question and underlined the answer. LMFAO.
Old Jul 11, 2010 | 06:46 PM
Redefined1's Avatar
that doesnt make you correct.
Old Jul 11, 2010 | 06:47 PM
rico's Avatar
tune a car on meth. and with the same same mods tune it on e85 and tell us results easiest way to see i guess lol
Redefined1's Avatar
with my methanol MIXED with 94 octane comes out with 120 octane. that means thats what my motor is getting. so if you flow your e85 you will get 94-96 octane. All im debating is what octane rating is higher.
Old Jul 11, 2010 | 06:53 PM
rico's Avatar
http://www.modularfords.com/forums/s...E85-109-octane
cool read i found
Old Jul 11, 2010 | 07:02 PM
Redefined1's Avatar
Originally Posted by rico
that thread has the same mathmatic equation (r+m)/2 its funny how the other guy thinks since its pulled off wikipedia its wrong. so lets go with a 109 ocatne. it still doesnt beat my 120. so lets not listen to the other false information that guy was throwing around.
Old Jul 11, 2010 | 07:06 PM
05Slowline's Avatar
Bro you are retarded. You're slinging around numbers that you don't know **** about. Your meth does not equate to 120 octane sorry to burst your bubble but wikipedia isn't the solve all.
You are probably not even over 110 with meth injection, sorry.
Old Jul 11, 2010 | 07:08 PM
Redefined1's Avatar
You are not even over 110 with meth injection, sorry.
how do you know what my mix is? idiot.... now you can stop talking thx.
Old Jul 11, 2010 | 07:09 PM
rico's Avatar
idk notmatter what ill do e85 again over meth lots safer than a cable or nozzle ******* up and boooommbamm boom lol
Old Jul 11, 2010 | 07:13 PM
05Slowline's Avatar
I don't give a flying **** if your mix is 100% (which it isn't or you're a moron) your mix isn't going to equate to 120 octane. Plz tell me how you come up with that cause I can tell you how I disprove that .
Old Jul 11, 2010 | 07:14 PM
rico's Avatar
idk same mods cobalts pretty much when i was sc guy had a good mix of e85 and i was on 93 if not e85 and he got walked bad
