Meth Install Help
Old Jul 1, 2008 | 11:39 AM
Altiery54's Avatar
Originally Posted by Drakonen2000
altiery....good lord man....learn how to use a camera and not take blurry photos!!!!!
ha easy *******....
some1 answer joeys ?'s though cause i have the same1's lol
Old Jul 1, 2008 | 11:41 AM
Joeyavhu's Avatar
Haha, I feel like that pretty much covers all the questions I had. Lol
Glad to hear it will help you out too.
Old Jul 1, 2008 | 11:42 AM
Altiery54's Avatar
it will and i will be doing this 2nite so answers will be much appreciated.
joey we must be like twins seriously cause those are my exact questions
Old Jul 1, 2008 | 12:21 PM
Joeyavhu's Avatar
Okay, I figured out a little bit, as far as the relay, for the one I have
#30 - Blue - connect to fuse - then to 12v source
#85 - Black - connects to NO on the pressure switch (second from the top)
#86 - White - connects to Ignition 12v source
#87 - Yellow - Connects to red wire from pump
#87a - Red - NOT USED (**NOTE: This one is listed as 86a in the diagram in the instructions)
As far as wiring the pressure switch, the COM (which is the top pin) should be connected to a ground. The bottom NC pin on the pressure switch should not be used.
The pump should have the red wire connected to #87, which is the yellow wire, and it should have the black wire grounded.
Hope that helps a little as far as wiring.
Old Jul 1, 2008 | 02:32 PM
Josh@ottp's Avatar
The nozzle goes the other way. filter into the black 90 degree fitting
Old Jul 1, 2008 | 03:06 PM
Joeyavhu's Avatar
Lol... That is some good advice. I was wondering why in the pictures I saw the green fitting was facing towards the intake. Everything else is set up correct though? I laugh because I was wondering how it was going to go that way. Lol
Thanks for your help, I will be purchasing from you again.
Old Jul 1, 2008 | 09:18 PM
Altiery54's Avatar
the hose that came with the kit doesnt fit on the bottom of the T. and it doesnt fit on the psi switch. do u have 2 heat it up or something?
Old Jul 1, 2008 | 09:20 PM
chad463's Avatar
I am subscribing to this for when my kit gets here. Lots of good information.
Old Jul 1, 2008 | 09:54 PM
Joeyavhu's Avatar
Thats a good question. I am going to cut a small piece of the hose and just mount the pressure switch right next to the "T". That should be fine, I think. Lol
And.. I am very angry that my TB spacer is making it EXTREMELY!!!! Difficult to get my K&N Intake to match up. If I push it one way, it is up to high, and if I try to put it down, it goes straight into the TB itself and will interfere with the plate inside. GRRR!!!! Lol
Old Jul 1, 2008 | 10:37 PM
Josh@ottp's Avatar
That hose is for meth only guys. You have to get vacuum hose to mount to the tee.
Old Jul 1, 2008 | 10:45 PM
  #36
Joeyavhu's Avatar
Ahh... This is taking forever. Lol. Easy my... Nevermind.
Anyway, I guess that will be on my list of stuff to pick up tomorrow at Autozone.
  #37
Altiery54's Avatar
ha very good. i'll use the little piece i cut to mount the T thanks fast98
Old Jul 1, 2008 | 10:55 PM
  #38
Joeyavhu's Avatar
I think I am going to explode. Lol
And I may have to hack saw my intake because of the TB spacer... AHHH!!!!
Old Jul 1, 2008 | 11:16 PM
  #39
Josh@ottp's Avatar
Your CAI is to long?
Old Jul 2, 2008 | 01:43 AM
  #40
Joeyavhu's Avatar
Yea. Its the K&N Typhoon Intake and it is going to where when I go to line it up, it slips right into the TB and makes it so the butterfly plate inside can't open. I am thinking of just taping off the sides and taking a hack-saw to it and just cutting off a little bit, because I will still have that rubber adapter.
Also, what line exactly do we tap into for that "T" fitting?
Okay, so minor update. Being on this site for 2+ years now.. I have learned the secrets of the coveted search feature. Lol. You have to show it a little bit o' love to get what you want out of it.
This post should help with anyone who is confused about where to tap the line for a boost feed.
https://www.cobaltss.net/forums/show...tion+boost+tap
Old Jul 2, 2008 | 05:06 PM
  #41
Joeyavhu's Avatar
HOORAY!!!!! I finished!!!!!!
Jan 12, 2016 12:01 AM
justinchinn
Oct 2, 2015 12:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
