Meth mix
Oh in case nobody sait it always make sure you use distilled water, no mineral or tap water, you need something pure. Imo run 100% I have no worries about knock and I run a pretty aggressive timing map, the term mid-range animal has been told to me once or twice lol. I just don't like messing around mixing **** and at
more meth, more octane, water does do the most for cooling so there is going to be the point where you start losing cooling benifit, there is tons of threds on this, including a whole methanol thread
Do not run more than the 5gph with your set up.
Do not use windshield washer fluid. You're better off pissing into your intake. 75/25 meth/h2o
HP will depend on how aggressive your tune is. I would guess about 270 whp, maybe more, if your tuner doesn't Fail. I used to run a 2.8" m62 with only zzp catted dp, stock catback, stock exh manifold, and the 3gph nozzle on a 75% meth mix. I put down 265 with 25* of timing. It had more in it too.
