View Poll Results: How much methanol are you consuming per TANK of gas.
1/4 gallon
14
53.85%
1/2 gallon
15.38%
1 gallon
3.85%
2 gallons
15.38%
2+ gallons
11.54%
Voters: 26. You may not vote on this poll
Methanol Injection Cobalts!
Can't be too sure, its the same as the windshield washer tank and I use it to clean my windows as well as spraying during high boost.
I top it off at the begining of each month and it never uses a whole gallon. I go through about 5 tanks of gas a month.....
bump for more votes.... i cant see how people are using 3 gph nozzles and only using a 1/4 gallon per tank unless they baby it.
takes 30 min to get to work and if i laid on it for 10% of the time = (20 min per gallon) 1.5 gallons for 100% * .10 * 2 (for returning home) = 1/3 of a gallon for 1 day.
wtf nozzles are you guys using? .5 gph?
Unless you are running a TVS or super small pulley on the M62 there is NO reason to go through that much!
My meth kicks on at 4 psi and goes to 18 psi and I don't even go through the washer fluid tank in a month!
But I don't beat the **** out of my car day after day!
2.8 @ 15 psi
oh....my.....god
Macgyver2484
Sep 2, 2015 05:44 PM
