mod questions
Old Nov 10, 2008 | 10:29 PM
AnthonyCM's Avatar
mod questions
i'm lookin to make my car faster but don't have that great a cash flow at the moment. i've already done the air box mod. what all else are some good mods that don't run to pricey?
Old Nov 10, 2008 | 10:31 PM
cobaltR's Avatar
not much really, gotta pay to play. I'd say header back exhaust. Then save up to do a pulley and tune from there...power wise. I'd also look into getting motor/trans mounts to eliminate wheel hop, if you havent already.
Old Nov 10, 2008 | 10:35 PM
AnthonyCM's Avatar
no not yet just the air box mod....been lookin into the motor mounts cuz wheel hop sucks with these cars
07SSCharged248's Avatar
Horse power aint cheep
Old Nov 10, 2008 | 10:36 PM
thc's Avatar
thc
cooling mods would be a good thing to look into
Old Nov 10, 2008 | 10:40 PM
G85 SS's Avatar
^^^ Troof. Since he doesn't have a lot of cash flow he can forget about going up to bigger injectors and smaller pulley. You could actually get an intake for fairly cheap. But, I do believe your best route is cooling mods. Start with a CX Heat Exchanger. Complete kit on OTT is $235. Dual pass is also another option and a little cheaper. $150-ish on ZZPerformance. That's all I can really think of to be honest. Unless you went for appearance mods.
Old Nov 10, 2008 | 10:45 PM
AnthonyCM's Avatar
??? 42# + 2.9 runs like $245 so not much difference from heat exchanger
Old Nov 10, 2008 | 10:47 PM
bboyfreeflow's Avatar
how much do camshafts run ...for 2.2's , curious
Old Nov 10, 2008 | 10:50 PM
AnthonyCM's Avatar
http://www.zzperformance.com/cobalt_...=862&catid=174
$650
Old Nov 12, 2008 | 09:01 PM
AnthonyCM's Avatar
Old Nov 12, 2008 | 09:07 PM
CobaltLs_14's Avatar
do ur suspension...
Old Nov 12, 2008 | 09:10 PM
qwikredline's Avatar
PM me or Josh at OTTP this is your next mod....saves you money lol
Old Nov 12, 2008 | 09:16 PM
tony2toness/sc's Avatar
try stickers they put down massive power lol
Old Nov 12, 2008 | 09:37 PM
Johnboy12358's Avatar
No no no! Thats the double stacked spoiler, stickers are only supporting mods.
Old Nov 12, 2008 | 09:50 PM
freakta's Avatar
id say do the cheapest cooling mods like a 50 dollar cobra heat exhanger, port your sc, and port your intake manifold. and while your doing that save your money for a tune. it is the best bang for buck. find someone local get on there good side and pay 500 bucks for a tune, it will raise your rev limiter make your car run cooler, make more power, and get better traction all for one lump sum
Old Nov 12, 2008 | 10:05 PM
AnthonyCM's Avatar
what should i raise it to? was thinkin 7250.....is that good or someone know any better?
Old Nov 12, 2008 | 10:30 PM
cobaltR's Avatar
But dont forget you need to tune for that! Plus cooling mods should really be done if drop down in pulley sizes....its not a MUST for the 2.9 BUT I HIGHLY suggest you do it. Just remember heat is your biggest enemy with superchargers.
Also take his word on this.....btw did you get issues fixed on your ride????
Old Nov 12, 2008 | 10:48 PM
G85 SS's Avatar
Not to mention you need to tune. Also, you need to get a reflash done on your vehicle. All of that will add up to at least $400 unless you know how to do everything yourself. Installation, tuning and reflash. And I believe the reflash has to be done at a dealership, don't quote me on it though.
2.9 pulley with hub ~$100
42.5 lb injectors and harness ~$200
Shortened Belt ~$35
Step 1 or 2 Colder Plugs ~$10 - ~$30 (Iridium plugs are what I have)
All of that is BEFORE your tune and reflash. And if you want to play things and be safe by going through GM it will cost you ~$900 for just the parts and who knows how much more for labor. They upped their price of the Stage 2 Kit.
A lot more to going staged than just slapping on a smaller pulley and getting bigger injectors.
Old Nov 12, 2008 | 11:09 PM
DONT raise your revs. 6800 is just fine 7k if you must.... try psykostevo for a great tune...
Old Nov 12, 2008 | 11:16 PM
G85 SS's Avatar
^^ Would you even see any noticeable results from raising the redline on a "stock" SS/SC? I would think maybe a little but nothing really worth it.
Old Nov 12, 2008 | 11:18 PM
exactly..................................
Old Nov 12, 2008 | 11:23 PM
G85 SS's Avatar
Yea, that's what I thought...
IMO, if he is kinda tight on money and wants his car to be "faster" he needs to start focusing on cooling mods. All together they will yield pretty good results on a stock SS...Just do some hunting around about cooling mods. You might be surprised.
Cause speed doesn't just come from tiny pulleys and big injectors.
Old Nov 13, 2008 | 09:45 AM
x 2 good point
Old Nov 13, 2008 | 08:21 PM
Maxim_X's Avatar
Nitrous = $450 for a wet kit + $50-$500 for install and possibly 300whp if you spray enough.
I'd recommend a wideband to got with it .. About 230$
Old Nov 13, 2008 | 08:25 PM
AnthonyCM's Avatar
what you mean issues?and whats the reflash do?
