More GM Stage 2 questions
So I owe my dad around 2k for the balt still (No modding till its off.) But since I've been destroying all my college classes he said he would buy me GMS2 and an intake and just add it onto my debt
So I know GMS2 is Injectors pulley and a canned tune, does this raise the rev limiter to 7.2k or is that only ZZP/OTTP
And for the intake I assume it would matter if I Installed the intake before or after the Stage kit, I'm assuming after would be simpler since it the car would only have to learn it once instead of relearning again it after the GM tune
I'll talk to my dad, like I said he's buying it so ultimately it sup to him since it will be put onto it while it's still technically his, and He likes the fact that It's installed by GM and all that since he hates me modding cars haha
OP, please use search button .... there is a million threads on information pertaining to GM Stage 2, or any stage kit for that matter.
To answer your question ....
GM Stage 2 = 77.9 pulley & hub, shorter belt, 42 lb/hr injectors, Tune, 7,000 rpm limit.
yea if the warranty is up then definitely push for the ottp or zzp kit
you will make alot more power than the gms2 and the tune will be better plus u can set ur limiter up to i believe 7400 if u like. just make sure you get the proper cooling mods
Which you should not do unless you have upgraded valve springs.
Ugh, I hate reading threads about "My daddy owns the car, and I have to ask permission" These cars are already getting to the teens.
Anyways, OTTP is the best route
Not to rag on GM techs but I have heard in some instances that a few dealerships don't even know about the Stage kits, if you are mechanically inclined or know someone that is I'd go with the ZZP/OTTP
Iceberg
Sep 29, 2015 12:33 PM
