More test results for you guys. Want more HP?
Old Jun 15, 2006 | 11:35 PM
FAST06SS's Avatar
Well for the past couple of trips to the track i have been testing a couple of things on my Cobalt so i thought i would share them with you and change the mood of post
#1) I have switched to an LT1 MAFF and a 3.5"id air inlet hose and a 9" K&N. Results were promising, i picked up 2mph in the 1/8th and 1.5 in the 1/4. Unfortunately, the added power has made me REDUCE the boost in 1st gear via HPTuners to allow me to hook up, somewhat! This had not allowed an improvement in ET's but with traction on a prepped track or thru better tires, 12.5 or 12.6 is a reality. The car feels incredible from any speed! SC whine is deafning! Consistent 109 trap now which is nice. Oh yea, i have 90.00 in the intake set-up!
#2) I added a second stock heat exchanger mounted in front of the ac condensor and hooked up in series with the orginal unit. I saw a 15-20 degree drop in IAT2 which allows me to run more timing on my pump gas tune which is nice on the street. I feel that adding a resvoir and bigger pump, a 40-50 degree drop could be realized.
That's it for now, i won't be able to race for awhile as i need new rims and tires and can't afford them but if i come accross any more good HP mod's i'll pass them on to you.
Rob
Old Jun 15, 2006 | 11:55 PM
djt81185's Avatar
I WANT A WORKING CLUTCH LOL!!!!
Glad to see those worked for ya...you and jamie just got me by a lil on the hwy
Dan
Old Jun 15, 2006 | 11:58 PM
Asphalt Assault's Avatar
Where did you find the pipe? would love to make my own CAI. did you use any part of the stock box?
Old Jun 16, 2006 | 12:08 AM
FAST06SS's Avatar
Intense has the duct and you need 3'. You also need a 3" to 3.5" adapter. I did not use any of the stock box. It was all totally removed to make space for the K&N.
Old Jun 16, 2006 | 12:15 AM
Ljavy17's Avatar
so ur keeping the car huh!!!!!!!!!!
Old Jun 16, 2006 | 12:22 AM
FAST06SS's Avatar
I'm trying to, this was all done prior to this weeks bad news. We are doing better and are trying to figure out some ways to make it all work.
Old Jun 16, 2006 | 12:28 AM
BooSSted's Avatar
Personal issues or business issues?
Old Jun 16, 2006 | 12:40 AM
FAST06SS's Avatar
Both
Old Jun 16, 2006 | 12:49 AM
Cobalt_Supercharged's Avatar
Very nice. Hope all works well for you and your family. I would really like to see you continue your power pioneering.
Old Jun 16, 2006 | 05:16 AM
SilverSS/SC's Avatar
Ive already got my intake mocked up , I just need to get down there to indy to have ya do the tuning needed to except the new maf . I knew Id have a use again someday for my old spare LT1 maf
Were you able to find a used heat exchanger ? Ive tried looking with no luck as of yet . Its pretty pricey thru the dealer , even with my discount
Old Jun 16, 2006 | 07:45 AM
FAST06SS's Avatar
Couple of choices, 280.00 for a stock one (easier to install) 80-100 for a used stock cobra unit or 370.00 for a new aftermarket cobra unit. The later might be a little better but install would be a little harder.
Rob
Old Jun 16, 2006 | 07:55 AM
Doc's Avatar
Doc
Rob....Thanks, a ton...
Old Jun 16, 2006 | 08:02 AM
blkcobalt's Avatar
Wow..... Thanks for the info. Next time you go to the track, PM me..I'd like to come over and watch you run. I assume you are going to IRP?
Old Jun 16, 2006 | 08:16 AM
Chevypowered's Avatar
Dang it, i was about to add a 26" X 8" X 3" water intercooler for mine before i sold it but i lost steam in doing so because no one thought it would be worh while, I should have known better.
Old Jun 16, 2006 | 08:18 AM
Saki XL's Avatar
Rob, have you considered Water/Meth injection to your tune yet?
Old Jun 16, 2006 | 10:54 AM
GSoccer24's Avatar
Rob, any issues with the Spec Stage 3+ clutch in relation to what people have found out about our master/slave cylinders, etc.?
Old Jun 16, 2006 | 12:42 PM
NightmareRacing's Avatar
what is involved into converting to LT1 maf? any reprogramming or just a straight plug and play (I would asssume you have to reprogram...)
hacadacalopolis
Oct 28, 2015 06:09 PM
tomj77
Oct 4, 2015 11:39 AM
Trav3480
Sep 28, 2015 02:46 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Dirtybutwhole
Sep 26, 2015 06:53 PM
