My 600WHP Build has started
My car is a 2006 Cobalt SS and here is what i'm doing to get this beast to put down some good numbers:
Head:
Full Race Port and Polish
Hot-Air Flow Benched Intervals
Glass Beaded
Knife Edged Intake Runners
Knife Edged Exhaust Runners
Port Matched Intake
Port Matched Exhaust
Ferrea LSJ Special Alloy Valve Springs
Viton Valve seals
5 Angle Valve Job
Ferrea Special Alloy Stainless Steel Valves
Ferrea Titanium Retainers
Ferrea Spring Seat Locators
Titanium Locks
Bronze Valve Guides
Cometic MLS Head Gasket
Milled Head
272 Intake and Exhaust Cams
Block:
Wiseco Forged Aluminum Piston Kit 8:5:1
w/Ceramic Coated Piston Crown
Total Seal Gapless Piston Ring Kit
Xenon Hyper-Alloy Piston Pins
Wiseco Spirolox
Cross-Beam 4340 Connecting Rods
GM Main Bearings
Connecting Rod Bearings
Balance Shaft Bearings
Custom 4340 2.0L Crankshaft
Knife-Edged, Lightened, Balanced
Locked Oil-Hole Direction, Cross-Drilled
Masonite Custom Cylinder sleeves
GM Perf. Parts Neutral Balance Shafts
Bates Engineering Oil Pump Gears
Dead-Lock Timing Chain Tensioner
Intake and Turbo Parts:
Hahn's Sheetmetal Port Fueler Intake Manifold
Vulcan Turbo Exhaust Manifold
Forced Performance 3065R Turbo
Tial 55mm External Wastegate
HKS BOV<<<<still ?able dunno on that one yet
FMIC
Tranny fully built By TRE in Michigan with LSD
Spec stage 5 clutch 9lb Flywheel
3'' Exhaust with catless DP
Thats all I can think of for now other then little crap.
I would like to thank the U.S Army for the huge 20,000.00 Re-Enlistment bonus for the national guard to build this beast
Head:
Glass Beaded
Port Matched Intake
Viton Valve seals
5 Angle Valve Job
Titanium Locks
Bronze Valve Guides
Milled Head
Block:
Wiseco Spirolox
GM Main Bearings
FMIC
Thank you Thank you....surely there are going to be some people that have dumb **** to say...but thanks...lookin foward to driving it again =)
about 25K worth of stuff....alot of it is already done just waitin on small stuff to get done....Waiting on tranny to get back
Well the reason I'm doing this is b.c after 36K on the motor the number 4 piston ring broke and scared the sleeve. I have a 2000 BMW for a DD and this is just going to sit and be a good project and drive it on weekends....I'm at Ft. Dix N.J right now so I have nothing else to do then dump money into the balt...I have not bills other then rent 400.00(roomate) and car payment. No insurance b.c it has not motor and sits in a garage
so around 800 a month is bills army pays me 4000.00 a month to sit on my ass here and look on the computer all day
Never gonna happen. I'll give you 450whp on pump gas. This sounds more like a mod list off Gran Turismo...
You're not gonna get enough revs out of that valvetrain without floating valves. Also, what kind of lift are you planning for with the cams? I'd try for a 10.8/10.2 and get yourself some solid lifters. BLE makes em for the Ecotec and they are a better way to go than the JBP ones you have to shave or trying shims that will just end up floating around the head anyhow. And I'm not sure if you've really done your homework or not but the 3065R is not going to support 600whp unless you are running C16 and some serious timing, and even that is stretching it with 8500rpm worth of revs.
Yes they can make different final drives...They told me whatever you want done we can do it...If we can't find stronger parts for it then we will make sronger parts for it. My tranny is the first one that they have built so once it's done and i will let you know what all they did and how much everything cost....
I just love that whole month tax free even if you fly over the CORNER of a hostile fire area rule.Great-Build list BTW, my #4 piston just did the piston ring damage dance so I'm starting a rebuilt soon as I get back around the end of the month, Im only shooting for about 400whp with a Turbo kit....
To bad its front wheel drive
you could have put 5k down on a STI put 6-7k into that and boom 500WHP and AWD
HEHE
Ryan
Also, With that compression and a 30R you wont make 600 WHP. The turbos to small man!
HEHE
Ryan
