My 600WHP Build has started
Old Mar 4, 2009 | 10:12 PM
  #126
Armyguy151's Avatar
got a question that a friend of mine was thinking about doing. Would the new LNF motor fit into a older cobalt? I know that wire harness is different but if the motor came with all with wire harness and pcm would it fit...I think it would considering they are both 2.0! Just wanted to ask and see what people thought
Old Mar 4, 2009 | 10:14 PM
  #127
HunterKiller89's Avatar
^^ physically, they would fit, but there would be some wiring issues that arise. You'd have to check in with someone who knows more about the LNF electrical system for specifics
Old Mar 4, 2009 | 10:16 PM
  #128
car_guy_09's Avatar
My first question would be why?
Old Mar 4, 2009 | 10:52 PM
  #129
Armyguy151's Avatar
who knows...why do people do the things they do...i believe it comes with all the wire harness and the PCM
Old Mar 4, 2009 | 10:56 PM
  #130
jrocstar's Avatar
want 600 wheel? run a 150 shot with that turbo problem solved. You can do it but you are going extremely far beyond the efficiency island that turbo is meant for. a 600 hp turbo is 60-1 or 35r at their peak performance. just throw a 37r on there and you can **** alot of stuff up real quick.
but i hope you make that mark. i just had the exact same thing happen to my lsj and am building it up staying with the supercharger. out of curiosity where are you getting the total seal gapless ring kit from?
Old Mar 4, 2009 | 11:50 PM
  #131
Micro's Avatar
I am looking forward to the results of this build. Thanks for serving our country!
Old Mar 5, 2009 | 12:27 AM
  #132
when i say electrical issues, i mean outside the harness and PCM...additional electronic issues
Old Mar 5, 2009 | 12:37 AM
  #133
steddy2112's Avatar
It wont run without a BCM too.
And ABS from one
And...the list goes on and on
Old Mar 5, 2009 | 01:05 PM
  #134
Psykostevo's Avatar
And ABS from one
He'll figure it out. Sounds like he thinks he has the money to make it work.
You would have to tackle the fuel issue, because as it stands the fuel system cannot support 600whp. Not even close.
Old Mar 5, 2009 | 01:14 PM
  #135
switch to return style fuel, run 79# injectors, and increase the voltage to the fuel pump (or buy a better flowing pump?)
Could the above be a feasible solution? I'm just curious for my own sake.
Old Mar 5, 2009 | 01:17 PM
  #136
Prosport Gauges's Avatar
I would hate to see you spend money on a 30r and realize it wont make your intended goals. So take all of our advise and go bigger.
I also recommend you sleeveing the block. If you dont, i can only see the motor lasting 15-20k miles.
Old Mar 5, 2009 | 04:11 PM
  #137
Area47's Avatar
Rent me! per hour
bring me the car {the lnf swap you want to do} and money. i can do it
Old Mar 5, 2009 | 04:17 PM
  #138
Psykostevo's Avatar
He was talking about making the LNF work for that.
LNF Smartcar?
Old Mar 5, 2009 | 04:22 PM
  #139
Area47's Avatar
Rent me! per hour
terbow busa sm4rt c4r
Old Mar 5, 2009 | 04:33 PM
  #140
VictoryRed06's Avatar
damn thats a **** load of money
Old Mar 5, 2009 | 05:04 PM
  #141
Psykostevo's Avatar
That's no fun, people are already doing that.
I think Russia put people into space for less than what he's paying for parts.
Old Mar 5, 2009 | 05:08 PM
  #142
06black's Avatar
if you had an 07 car to swap, then yes, it would be pretty straight forward as the CAN and TCU/BCU are all 32bit like the the LNF is.
05/06 cars would require one hell of a re-wire.
Old Mar 5, 2009 | 05:46 PM
  #143
glen229's Avatar
you will put down good numbers for sure, but definitly not 600
Old Mar 5, 2009 | 06:23 PM
  #144
really? i should look into that then...thanks
Old Mar 5, 2009 | 07:51 PM
  #145
burntorange's Avatar
that's what I am currently building!!!!
Old Mar 5, 2009 | 09:20 PM
  #146
Area47's Avatar
Rent me! per hour
for the past couple days i have been driving an evo that put down 517 with a pe6262. drives just peachy. you can drive them just fine on the street and be more than happy and pass people with out going wot to get around them.
Old Mar 6, 2009 | 07:03 AM
  #147
jrocstar's Avatar
i would not complain with that
Old Mar 6, 2009 | 03:19 PM
  #148
2K5SS/SC?'s Avatar
Please PM with the tranny build info. I am very curious about the price and what they are doing to make it stronger!
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
