My 600WHP Build has started
I'm not gonna argue that point man, I take my own car to 7500rpm all day long with 100% stock internals. It's when you add the stress of a longer duration/bigger lift cam that things get hiary.
I'm sure the kid that doesn't know what the term "lash adjuster" means will probably say impossible or it was eventually doom to fail.
now, if the pressure is too high. it takes more power to turn the cam and more stress on the cam itself, the timing chain and everything associated with that. granted you can run higher rpms and sustain them longer, but you also wear out the cam lobes way too fast and it is over from then on out.
Ran .425" lift with lash adjusters stroked 1.3mm on 200lb open spring pressure daily to 8100rpm for 40,000 miles without a single failure. I doubt anyone on this board has done anything more severe than that.
I have 4 mos's but my primary is 31E (MP Cage Kicker) 31B (MP),11B (Infantry) 11C (Mortars)...right now i'm a e-5 getting premoted to e-6 soon....Also 600 is my goal and it can be done. so it doesn't matter what everyone says about this and that...ITS NOT MY DD!!!!! if the 3065R doesn't make it then oh well a little juice will make up for the 50 or 75hp! This site has so many haterz that it's unreal....
i've noticed every time someone makes a build thread there are always tons of people saying you cant do this and you can't do that. People should get on here to help other people not down grade what they are doing? Is it b.c your jealous that your not doing it???? i'm just saying tons of people always talkin crap....never said that i was going to be the fastest cobalt in the world but i want to build this car and have a decent car......
Anyways, good luck with the build.... do more research on parts!
Sorry man, not hateing here. Just giveing you striaght and honest facts. The 30R wont do it. 4 MOS's huh, thats pretty weird. I dont see how your a E-5 with 4 MOS's Unless you have been in for like 10-12 years. I spent 4 years as a 19delta "scout" I got out a E-5
