My LSJ head is ruined :(
Old 05-01-2013, 09:34 AM
  #76
Clean06SC's Avatar
I guess anything is possible. I do have like the highest mileage lsj in my area I'm pretty sure. 113,xxx. And then again, there's only a handful around. Huntington, WV is more of the mustang scene.
Old 05-01-2013, 10:04 AM
  #77
Vander Nars's Avatar
there is a lsj at 200k I seen on facebook group not sure who has the highest mileage but hope you get it fixed.
Old 05-01-2013, 10:21 AM
  #78
South Central *********
JapEatr's Avatar
i did a clutch on a buddys redline which had 220k miles on the original clutch
Old 05-01-2013, 03:30 PM
  #79
Clean06SC's Avatar
Thanks. I should be go to go when I buy the head from mexi_loco. Then timing chain kit and etc.
Old 05-01-2013, 03:39 PM
  #80
Clean06SC's Avatar
Old 05-02-2013, 11:11 PM
  #81
Clean06SC's Avatar
Well bent AT LEAST 6 valves and the a guide bolt melted in the head as machine shop can't fix it (
Old 05-02-2013, 11:38 PM
  #82
armcclure's Avatar
Melted a guide bolt? Do tell.
Old 05-03-2013, 12:19 AM
  #83
c130aviator's Avatar
How did I not see this?
Well this definitely puts to rest my reading that the 2.0 is a non interference engine (read it somewhere during my engine build research). Definitely some interference here when out of timing, LOL. Especially if there was enough force to break the lash adjuster from the piston hitting the valve.
I have redone my timing due to a broken LSJ tensioner (replaced with the revised AC delco tensioner) and then a broken bolt. Both times I took my time and didn't rush. I also knew what I was doing before I started the car...
x2
Old 05-03-2013, 11:52 PM
  #84
Clean06SC's Avatar
It grinders down and broke off into the head and some how melted? I have no clue. The machine shop was clueless also. Hopefully this head I just bought checks out.
Old 05-04-2013, 12:02 AM
  #85
well good luck, i had that sinking feeling the first time I burned up some valves on a bad tune and over zealous boost controller.
Old 05-04-2013, 12:15 AM
  #86
Clean06SC's Avatar
Yeah. I'm literally walking. It's my dd and now I'm broke.
Old 05-04-2013, 08:57 AM
  #87
mexi_loco's Avatar
The head should be good to go. The only thing I would probably consider for peace of mind is decking the block. Iirc, that's standard procedure with a new head.
Old 05-04-2013, 10:49 AM
  #88
I dont think he needs to mill the block. Just the head. That is how I did it my first build. Sealed just fine until I blew the sleeve. When I built the engine and sleeved it then I had the block milled as well.
Old 05-04-2013, 11:07 AM
  #89
mrbelvedere's Avatar
that is not standard procedure
Old 05-04-2013, 11:41 AM
  #90
armcclure's Avatar
I think he meant head
Old 05-04-2013, 12:20 PM
  #91
Tjolley's Avatar
Put a straight edge across it. If u dont see light slap that bitch on with some copper spray.
Old 05-04-2013, 12:22 PM
  #92
you dont need copper spray with the oem MLS headgasket
Old 05-04-2013, 12:26 PM
  #93
Tjolley's Avatar
I would use it anyways..
I dont use the stockers.
Custom cometic all the way. I was told by a very reliable source to use cometic
Old 05-04-2013, 12:32 PM
  #94
I had a cometic at .051 thickness custom made, looked at it and a new GM MLS next to each other, the quality isnt even close. The Germany made GM MLS headgasket is a much nicer piece. If you dont need the lower compression the stocker is hard to beat.
Old 05-04-2013, 12:35 PM
  #95
574
574's Avatar
Thxgovenors he's gasket has to be replaced not too long ago, it was cosmic... Just saying
Old 05-04-2013, 12:36 PM
  #96
Tjolley's Avatar
Im just going off wat ray bates told me. And wat he uses
Old 05-04-2013, 12:42 PM
  #97
thankfully i was able to return my cometic and get my 100 bucks back. I am running the GM one now.
Old 05-04-2013, 12:46 PM
  #98
Tjolley's Avatar
I have over 35k miles on mine no issues
Old 05-04-2013, 12:58 PM
  #99
574
574's Avatar
NWSS also popped one
Old 05-04-2013, 01:05 PM
  #100
zrated89's Avatar
SSSSOOOOOOOOO Much s in this thread. One at the OP and 2 at some of the dumb ass responses hes getting LMAO
Quick Reply: My LSJ head is ruined :(
