Need help Diamond piston guys
hey guys,
I am currently installing my diamond pistons into my car I was wondering do I have to bore out my rod to get the piston wrist pin to fit? or are they pressed in?
thanks in advance
thanks in advance
Inline motors do not need balanced.
You can re-use OEM wrist pins if you want. I've done installs both ways without any issues.
Reason they don't fit is one manufacturer just has a tighter spec tolerance than the other.
You can get Total Seal Gapless rings, but ones shipped with the Diamond pistons by default, are file to fit.
